So I bought the carb diaphragms on ebay...anybody use these???
Discussion in '1st & 2nd Generation 1983-1989' started by dodgeaspen, Jun 20, 2011.
  1. dodgeaspen
    dodgeaspen New Member
    I had three out of the four carb slide diaphragms ripped on my 85 VF700 so I purchased the 4pc kit from ebay. Anybody install these before? The seller gives partial instructions but no info on how to attach then to the slide...or get the old ones off of the slide. Any help would be greatly appreciated!
    Thanks!
  2. larrown
    larrown New Member
    Satellite Beach, Florida
    What came in the four piece kit? Did you purchase just the rubber diaphragm boots?
  3. dodgeaspen
    Just the rubber diaphragms
  4. dodgeaspen
    Just for those who might need this info- I installed the diaphragms and the went on pretty easy. Seem to work correctly so I'm happy!
  5. squirrelman
    Please post a link to seller so others can reference the source.
  6. ferrarone
    ferrarone New Member
    Manchester, NH
  7. dodgeaspen
  8. ferrarone
    Manchester, NH
    If that works out its a fantastic solution and price.
  9. dodgeaspen
    So far they worked out well. Not too bad to install but the diaphragms were made a little sloppy. One problem was the hole for the vacuum port on the top of the diaphragm wasn't even open when I got them. In the big picture they work fine.....and its the only solution out there
  10. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    How did you change them? Do they just pull off? I didn't think they could be changed easily if at all.
    Nice to know they can.
  11. dodgeaspen
    Not too bad. Had to spread the the plastic pieces on the slide apart a little with a screwdriver to get the old ones out. Used some "lube" and a small screwdriver to get the new ones to slide in between the plastic pieces
