Soft Clutch Lever?
Discussion in '3rd & 4th Generation 1990-1997' started by faran, Jul 19, 2024.
  1. faran
    faran New Member
    So 4th gen motorcycle has been parked in the garage for quite sometime, starts okay and have been keeping up with fresh gas or stabil.
    It starts and have not taken it out on a ride but whenever I press clutch lever it seems too soft? What could it be?
    Thanks fellow VFRs for the help.
  2. bmart
    bmart Insider
    Charlotte, NC
    After such a long break, have you bled it and checked the activation shaft?
    mello dude likes this.
  3. faran
    faran New Member
    No, have not done anything and will start with bleeding as the first one, where is activation shaft? I mean with lever can hear a clicking(switch?) engagement.
    Thx @bmart
  4. bmart
    bmart Insider
    Charlotte, NC
    When you move the lever on the master, the fluid pushes a piston on the slave which in turn pushes a shaft (into the actual clutch assm.). That shaft can get pretty grimey. It won't likely cause a soft lever, but I'd clean it so that you know you're starting at 100% after the bleed.
  5. mello dude
    Romania
    --- What bmart says... :thumbs:
