Sound when spinning rear wheel
Discussion in '3rd & 4th Generation 1990-1997' started by Wahlstrom, Oct 4, 2019.
  1. Wahlstrom
    Wahlstrom New Member
    Denmark
    Got this sound when spinning the rear wheel..
    Sounds like it comes from front sprocket area
    Or something is touching inside...
    The bike shifts fine, pulls fine...
    Think the sound has escalated since clutch work some months ago
  2. joeyvans
    joeyvans New Member
    Have you checked the front sprocket to see if there is abnormal play with the sprocket and/or shaft? Seems too loud to be that, but I think that needs to get addressed first.
  3. Wahlstrom
    Denmark
    The sound isn’t present now the bike is cold..
    Just span the wheel here in the morning
    Or at least it’s very subtle
  4. fink
    fink Member
    Check front
    sprocket
  5. Wahlstrom
    Denmark
    If I slack the chain, can it be lifted of the front sprocket..?
    If the knocking sound is only present when warm, is there any reason to look at it when cold?
  6. Wahlstrom
    Denmark
    Front sprocket check:
  7. joeyvans
    joeyvans New Member
    Can we assume that you spun the rear wheel after you got the covers off? Any noticeable shifting/sounds while you do that?
  8. Wahlstrom
    Denmark
    I ran out of time and had to assemble it again.. will try tomorrow..
    I think it’s the chain..
    Tried rolling it in 1st gear... but at that time I had also slackened the chain a bit, as some mentioned it could be a too tight chain.. but it does wobble a bit
    It tightens up when revving it, it becomes more stable...
