Speed and Gears Input (Thoughts)
Discussion in 'General VFR Discussions' started by Peter Napoli, Sep 14, 2021.
  1. Peter Napoli
    Peter Napoli New Member
    South Carolina USA
    Hello All again. I've had my 2001 5th Gen now for 3 months or so. I wanted to know at what Speeds/Gears should these bikes be in. I know it'll be different for most, however I'm sure that there's a general consensus as to what gear you'd normally switch to and at what speed. I find that I've gotta drop down to 1st or 2nd gear if I wanna accelerate at a much faster speed. For instance, like an on and off ramp to an interstate. Trying to accelerate in 3rd or any other higher gear is pointless; unless I have mechanical issues I'm just not realizing I truly have. I've never had the bike mechanically looked at and no one else has driven it to tell me if I do have an issue. Any input would help. Thanks ! ......Examples : 0-30mph 1st Gear 30-40mph 2nd Gear 50-60mph 3rd gear etc....
  2. Diving Pete
    If you ask SkiMad then any speed above idle = 6th - :)
    If I was on my Fireblade, then any speed under 50mph = 1st.. :uk:
    However, I rarely use a speedo to change gear as its the rev counter that tells me that. Rarely, will I change up unless its above 4500rpm. You want to avoid lugging the engine & that's it. If you want to go faster then change later - between 8 & 10k. If you need to go much faster then you need a different bike.
    Peter Napoli and skimad4x4 like this.
  3. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    I agree, I shift by the tach, not the speedo. 5,ooo rpm is fair acceleration, 7,000-8,000 rpm is spirited, and 9,000 to 11,000 rpm
    is "get a ticket if you're not watchful".
    The power will not be so jerky if the rpm's are higher.
    Peter Napoli likes this.
    I don't even use my tach unless I am going for "get a ticket if you're not watchful" mode. And then I should be "watchful", not watching my tach. Its feel, sound and desired result.
  5. NorcalBoy
    If the output starts nosing over, it's time to shift.
