Speed reading jumping around.
Discussion in 'Mechanics Garage' started by VFR1200, Jul 13, 2020.
  1. VFR1200
    VFR1200 New Member
    Calgary, Canada
    Hi,
    I used the bike on Sunday and had no issues. Going for a ride this morning and the speed keeps jumping around when it should be steady. It is also reading 10kph less than it should. So if I should be doing 80, it will show 70 but also jump down to 64, 66, 60 and then back to 70.... again I am doing a constant speed.
    To top it all off, the Fi light came on when I was approx 200 yds from home.... balls...
    Any advice help will do.
    Bike is a 2007 VFR800 with 12,000km on it.
    Thanks in advance.
  2. raYzerman
    raYzerman Member
    Millgrove, ON
    With FI light and speedo issues, I'd be looking for a ground connection issue and connection issues in general..... maybe The Drill?
    But if speed sensor signals are erroneous, FI system might use those signals.... any stored FI codes?
  3. w3bdevil
    w3bdevil New Member
    Finland
    Hyvinkää, Finland
    Keager and VFR1200 like this.
  4. VFR1200
    VFR1200 New Member
    Calgary, Canada
    I think this is probably going to be the problem. It is just that it has failed after only 12,000km.
  5. VFR1200
    VFR1200 New Member
    Calgary, Canada
    There were no codes before this. Everything on the bike was running fine.
  6. VFR1200
    VFR1200 New Member
    Calgary, Canada
    Just taken the speedo sensor off. The nylon nut, is not complete. The middle part is bare with metal sticking out. All the pictures I see of this shows it as completely covered.
    I will order a new nylon nut and hopefully this will fix my little problem.
    raYzerman likes this.
