Speedometer Error
Discussion in '6th Generation 2002-2013' started by RobVG, Oct 17, 2019.
  1. RobVG
    RobVG Member
    White Rock BC
    Anyone figure out the speedometer error on a 6th Gen?
    Probably varies a bit from bike to bike but was wondering what you came up with.
  2. vishwo707
    vishwo707 New Member
    Bunbury, Western Australia
    I tested my VFR speed with Speedometer GPS app and it came around 6-7% higher than GPS speed.
    Sent from my SM-G950F using Tapatalk
  3. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Probably about the same as any Japanese motorcycle, around 5-10%.
  4. Camp
    Camp New Member
    Easton, PA
    8.3 on mine, speedo healer.
  5. Boosh63
    Boosh63 Member
    Timmins, Ontario, Canada
    My 08 is out about 6%.
    I read that SpeedoHealers are not recommended on bikes equipped with ABS... this true?
    Sent from my Pixel 3a using Tapatalk
  6. Doug7200
    Doug7200 New Member
    El Segundo or Gardnerville!!!
    On my 2 6th gens, one was around 7%, the other is 9%+.
    Manufacturers were sued years ago for 2 reasons - showing speeds less than actual, and inaccurate mileage totals. People sued after getting tickets for speeding and speedometers showed lower than actual speeds due to tire wear and sizing. The other reasons is when MC's are leaned over, the diameter of the tire changes, resulting in inaccurate mileage totals.
    Accordingly, most MC speedometers/odometers read 7-10% fast.
    Boosh63 and vishwo707 like this.
  7. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    I don't think anybody sued anyone over their speedometer being inaccurate and builders then made their
    speedometers all read high. I've been riding bikes since 1963 and every Japanese bike I've ever owned
    has indicated a higher speed than actual speed. I've never heard of any such litigation, but I may have
    missed it. I had three Triumph's and they all read dead-on accurate, even though the speedo drive was
    off the rear wheel.
    I think the main reason was to make the Honda's and such seem to be much faster than they really were.
    Japanese bikes were pretty small displacement compared to the Norton, Triumph, BSA, and Harley, so
    they were always trying to show that even though their bikes were small, they could still be fast. And I
    think it just stayed that way over the years. Honda was big on saying their CB350 could "do the ton" and
    it could, according to the speedometer. So there were real benefits to it reading high.
    All JMO of course.
  8. RobVG
    RobVG Member
    White Rock BC
    Judging from other traffic, I 'm guessing 75 is actually 70. That's in line with the 7% estimates.
  9. Allyance
    Allyance Member
    East Bay, California
    8th gens are fairly accurate, I check mine against the radar speed signs around our area all the time, dead on,
  10. Camp
    Camp New Member
    Easton, PA
    It's a habit it seems with Japanese vehicles. Maybe in the conversion. I've had a couple Kawi's, a Susuki, even a Honda Civic that all read high. Tolerable. It's when you get into gearing changes that a healer is great. Quick ride with the gps or phone, find the error %, enter it in... Fixed.
  11. dbuzz77
    dbuzz77 New Member
    South Lake, Saskatchewan
    My 03 was 6kph high according to my gps. 2 is usually the norm on cars so i don't know why they have to be that far out
  12. 577nitroexpress
    577nitroexpress New Member
    Mines off +5 mph .
    used to be you could adjust tension on the needle spring, tighten to slow the MPH down, etc... That was in the cable days, now I'm not sure how it works inside the clock.
  13. Camp
    Camp New Member
    Easton, PA
    The speedohealer works thru the diagnotic plug so tru the ecu. Just changed my gearing again to 45t rear. Wasn't completely happy with 44t. You take a ride with your phone of gps to get actual speed, also note the speed displayed. Then take the smaller number divided by the larger. Either lowering or raising the gearing. Enter that sum number as percent into the healer, done.
  14. Boosh63
    Boosh63 Member
    I've always read that It's not wise to fool around with a speedo healer when you have an ABS bike. Is this true?
  15. Terry Smith
    Wouldn't that depend on how the system was configured? If the wheel speed sensors for the ABS are also used for the speedo then it sounds plausible, but I do not think that would be the case with the VFRs. Certainly the 5th and 6th gen draw the speedo signal from the gearbox output shaft. If the wheel speed sensor was used, gearing changes would not affect the speedo.
  16. Boosh63
    Boosh63 Member
    That makes a ton of sense and that is what I understood as well. I imagine that I let a few articles spook me and just live with the inaccuracy.
  17. raYzerman
    raYzerman Member
    Millgrove, ON
    No problem with ABS, except when both front and rear sensor signals are used, ie, for factory cruise control on an FJR. In that case, TWO speedohealer units are required and a side effect was cruise worked only in 5th and 6th, no longer worked in 4th...... but that's a unique situation.
