Starter bendix
Discussion in '3rd & 4th Generation 1990-1997' started by Rckslick333, Mar 27, 2020.
  1. Rckslick333
    Rckslick333 New Member
    Anyone purchase one for a gen 3? Trying to find one online but coming up short. Hoping someone had a part number, or maybe a spare kicking around thank you in advance!!!
  3. Rckslick333
    Thank you so much for the fast reply!!! I wonder if that’s the problem. It begins to spin and then sounds like it grinds out and then I come off of the button and do it again. Sometimes it catches for a while and sometimes it doesn’t catch at all
    Sounds like the culprit. How many miles?
  5. Rckslick333
  6. Rckslick333
    So what part would I be looking for on that link you sent me. I’m really unfamiliar with it
    Yeah... get it apart and see what you need. Might take just the rollers and springs to freshen it up. Sometimes #5 cracks.
  8. Rckslick333
    When I get it apart I’ll post pictures. :). Now when I pull the starter should I expect oil to come out? Might be a novice question but rather be safe than sorry
    Dont have to pull the starter. You should drain the oil before removing the right crankcase cover. If it was on it's sidestand, you might not drip any oil, but I would drain to be safe.
  10. Rckslick333
    Oh of course. You should be able to see both with the cover removed
  11. squirrelman
    unless the bigger parts are cracked, starter clutches are an ez fix, usually needing only a cleanup and maybe 3 new 50-cent springs.
    if you lean the bike against something a few degrees to the starboard side you won't need to drain oil to remove clutch cover.
  12. Rckslick333
    I wonder if that’s what it is. It wipes engage from time to time and I can crank for how ever long I want and then sometimes I get a couple cranks and it grinds out
  13. squirrelman
    in about 90% of problems like yours it's the starter clutch, not the starter itself and a well known vf/vfr problem.
  14. raYzerman
    raYzerman Member
    Millgrove, ON
    I'd agree, sounds like the starter clutch.... rebuilt the one on my old Magna, new rollers made it just like new although the old ones didn't look all that bad.
  15. Rckslick333
    I can take a video if anyone is willing to listen to it maybe you’ve heard it before and can diagnose it from there. I’m not sure how to add a video on here but I can text it to you.
  16. Rckslick333
    image.jpg Everything looks intact
  17. Rckslick333
    Another image
    I'd start with springs and rollers.
  19. Captain 80s
    Sometimes catches, sometimes kicks out and occasionally sounds like a rock polisher? That is likely the culprit. Seen/heard it on a bunch of customer's bikes.
    Rckslick333 likes this.
  20. Rckslick333
    I just noticed this which I think is right with the springs no doubt. image.jpg
