Starter switch assembly - compatability with later gen VFRs?
Discussion in '1st & 2nd Generation 1983-1989' started by moho, Jun 16, 2014.
  1. moho
    moho New Member
    Chandler, AZ
    Had an intermittent/flickering headlight issue on my '87 700F that I troubleshot down to the sticky starter switch. Can usually get the light to stay on if I pull the switch out a bit after engaging. Sure enough, could have saved a few hours of head scratching if I checked the forum first... Anyway, saw some posts that said later gen switch controls are a better design, and plug and play with the 2nd gen. How new can I go with a new assembly and still have it be plug and play? Is there another gen/year assembly that works best with the 2nd gen? Any suggestions would be much appreciated!
  2. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    You can go up to a Gen 5 RH switch, there is a locking pin you will need to drill a hole in your gen2 bar to make it fit properly.
  3. moho
    moho New Member
    Chandler, AZ
    thanks for the reply. appreciate the info!
  4. FMB42
    FMB42 New Member
    Is the '87 switch the same as an '86?
    Thanks!
  5. Dukiedook
    Kansas City, USA
    Yep.
    Not much differences between the two even between the 700 and 750.
  6. FMB42
    FMB42 New Member
    Thanks Dukiedook.
