starter system problem
Discussion in 'Mechanics Garage' started by rpicheme, Sep 26, 2006.
  1. rpicheme
    rpicheme New Member
    I have a 1987 VFR750.
    I went to ride home from work today, but when I pushed the start button . . . the starter didn't turn. This has happened a couple times before, but usually after pushing the start button a couple times, the starter would turn and the bike would start. However, this time it never did start. I'm hoping the problem is just a loose wiring connection, and it's just a matter of locating it. Is that the most likely cause (given the past intermittent problems), or is it likely something more serious?
  2. Vlad Impaler
    Vlad Impaler New Member
    Indianapolis, Indiana
    I'll make the assuption that your starter has a throw-out solinoid on it, which could make sticking a potential problem in addition to connections.
    If I am not talking out my backside (potential) you may get away with pulling your starter and cleaning it along with checking connections.
    Makes you long for the kick start....eh?:tongue:
  3. squirrelman
    starter
    in an emergency you can always just short across the 2 solenoid terminals, to get it cranking...................using a screwdriver or some such.................
    if that doesn't elicit a response from the starter, either your battery is toast or starter motor itself needs attention.
    read the shop manual!
  4. Justin-credible
    Justin-credible New Member
    Nova Scotia
    well, this is the experience i had with my old 83 750...sometimes it started, sometimes it didn't.
    The problem slowly got worse and worse. I felt like trashing the bike cause of it, it's embarrassing when you've just gassed up with a bunch of other bikes, and now your bike won't start...
    For me it was as simple as replacing the brushes in the starter motor, might have cost $30 cdn. The motor won't turn if the brushes are shot, no current going through the starter, but the solinoid will still click....justin
