Starter valve adjustment
Discussion in 'Mechanics Garage' started by duccmann, Jan 26, 2014.
  1. duccmann
    No mechanics here by any means, but have heard quite a few times here when people post that there steads stall when pullin in the clutch and stopping at a light or stop sign and it stalls, and the responce is adjust the starter valve.
    Can someone explain its purpose (starter, Duh) and how its done ? Thanks in advance, and remember no questions are stupid here RIGHT ?
  2. rjgti
    rjgti New Member
    regina sk
    do you mean sync the throttle bodies?
  3. rjgti
    rjgti New Member
    regina sk
  4. duccmann
    rjgti, thanks bud . Very edumacational.
  5. rjgti
    rjgti New Member
    regina sk
    np duccmann:biggrin:
  6. squirrelman
    Other possible causes are idle adjustment set too low and/or a dragging clutch.
  7. duccmann
    After mine stalled twice I just bumped the idle up with no problems since. So what are the symptoms of being out of sync? Stalling ? thats it ?
  8. squirrelman
    bad synch=poor idle, uneven idle, jerking at small throttle openings. If you can lower idle adjustment for testing as low as 600-700 rpms and idle is even and consistent, no adjustment needed.
  9. duccmann
    Cool thanks
