starter will not engage as if the safety switch isnt working
Discussion in '1st & 2nd Generation 1983-1989' started by jpurs007, Nov 17, 2013.
  1. jpurs007
    jpurs007 New Member
    missouri
    I am new to working on motorcycles but have learned alot over the past few months from reading VFRWORLD experts.
    I have an 84 Vf500f. Yesterday it started right up and I let it run for about 15 mins. I shut it down then hit the start button a few seconds later and nothing. I have a fully charged battery, the bike in neutral, kick stand up, clutch pulled, and kill switch off, still nothing. The starter relay doesnt even make a sound but does have power to it to the main post just not the post that goes to the starter. I was able to get the starter to engage by bypassing the starter relay with a pair of pliers but it won't run and the plugs wont even fire. This leads me to believe it has something to do with a safety switch wiring issue issue. The fuses are all good(unless there is a line fuse i missed) and the lights come on when the key is on, the headlight even goes off when I push the starter button. I messed with it all night.
    Some wierd things that happened while I was trying to figure it out last night:
    1. the neutral light will now come on when I pull the clutch lever even if it is in gear.
    2. I did get it to fire once with the starter button (not sure how or why) and it ran for about 6 seconds then died and now back to starter not engaging.
    3. one time when I hit the starter button the tach needle went all the way up then back down even though the starter didn't engage.
    FYI: I did order a new relay which will be here next week but I am not convinced it will change anything since it won't run when I bypass the starter relay to engage the starter. I did have CDI box go out recently but replaced it and it ran afterwards just fine. I wonder if whatever made the CDI box go out is now causing this issue.
    Thanks for the help.
  2. tinkerinWstuff
    The start button is problematic in the 1st gen. The button melts internally and the pivot tabs break making the contacts not energize the starter relay.
    As good a place as any to check.
  3. jpurs007
    jpurs007 New Member
    missouri
    I think you are on to something there TinkerinWstuff. I was able to get the bike to start by using a Flathead screw driver to do the job of the starter button tab. I took the button apart to clean it and bend the metal tabs for a better connection but it still won't work without the screw driver being used so I am just gonna order a new starter button.
    Thanks for the help. At first I was skeptical this would work because when I was bypassing the starter relay I couldn't get the plugs to spark. Again thanks for the advice.
  4. tinkerinWstuff
    You can upgrade the controls to the more modern and more reliable 3rd-5th gen from what I've heard. You might do more homework of your own if you go that route.
  5. squirrelman
    Picking up on the clue that the neutral light comes on unexpectedly, i conclude that your starter relay interlock DIODE must be replaced.
  6. jpurs007
    jpurs007 New Member
    missouri
    I have a starter relay and start button in the mail. They should be here anyday now. I got a start botton from a 4th gen VFR. I couldnt find much about compatibility with my 1st gen but I think it will work. I will let you know what happens when the parts arrive. Thanks for all the input.
  7. reg71
    Sikeston, MO
    cool. too bad all probs arent that easy...
  8. jpurs007
    jpurs007 New Member
    missouri
    Reg71, I think you jinxed me. lol. I guess the problem wasn't that easy.
    I put a new stater relay on and no change.
    I put the new starter button on and no change.
    I am thinking the problem has something to do with a safety switch. The reason I think this is because when I run a wire between the "black wire" and the "black and Green wire" in the start switch, then press the start button the bike starts right up and runs fine.
    I would just leave this wire jump in place but I am afraid it will drain my battery or worse cause something to overheat when riding. I am going to find a wire diagram and try to track the issue down. Any suggestions?
  9. jpurs007
    jpurs007 New Member
    missouri
    Ok, It is now back to life and I feel like an idiot.
    It was the fuse for the ignition. I had visually checked the fuses initially and they all looked fine. The starter even worked 2 times using the using the starter button. I pulled the fuse today to check it with a voltmeter and it shows bad. The metal inside the fuse was barely separated (the reason I thought it was good) and I assume that it was so close that sometimes the arc would jump the gap and the starter would work.
    Not all bad though. I needed to change the starter relay because someone had taken the fuse box off and ran a wire across anyway.
    As for replacing the starter switch, the new one came with throttle cables and my cables needed replaced anyway because the casing was cracked.
    TinkerWstuff: I also found out that a starter switch from a 4th Gen WILL work on a 1st Gen.
    Thanks for all the help. Next time I will take my time and check the easy stuff (Fuses) better.
