Starting Problem (probably buffonery)
Discussion in 'Mechanics Garage' started by mikkee1, Mar 13, 2012.
  1. mikkee1
    mikkee1 New Member
    Hi guys,
    Trying to get my 02 VFR back in service after its winter sleep. Charged the battery and tried to start it. Starter turns over no problem but the engine won't catch. It started to catch for a couple of seconds during the third or fourth crank, now it won't catch after multiple attempts. I removed the plugs and cleaned them since I sprayed the cylinders with preservative last fall. Made no difference.
    Any ideas before I shell out for new plugs?
    Thanks,
    Mike
  2. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Do you hear the fuel pump coming on when you turn the key? If she's cranking and wants to fire, sounds like fuel??
  3. prkultr
    prkultr New Member
    Coudersport, PA
    You can always spray a bit of starter fluid in the air box. If it does not start, then it's electrical. If it starts, then it's fuel related.
  4. squirrelman
    This problem won't be cured by new plugs if your bike was running fine b4 storage.
