Stator Issue
Discussion in 'Mechanics Garage' started by archer45, Apr 9, 2014.
  1. archer45
    archer45 New Member
    Illinois
    I just got an 03 VFR800 rode it for a week and the wire connector from the stator to the rectifier melted and stared smoking. Is this common and what does it usually turn out to be?
  2. rjgti
    rjgti New Member
    regina sk
    yes it is common, do a search on r/r and you will find the fix
  3. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Common is an understatement. You're not a real VFR owner until your R/R has cooked your wires.
    See this link. Contains all sorts of good info.
    http://vfrworld.com/forums/showthread.php/45019-Stator-Issue
    Separately, note the 2002 to 2005 models had a recall done on a wiring harness (somewhere in the front of the bike). You should make sure that's been done. A call to any Honda place with your VIN should reveal whether or not its been completed.
  4. mello dude
    Romania
  5. squirrelman
    Common all gens.........
    Of any two yellow wires touch due to melting, it fries the stator instantly.
