Stator/RR ???
Discussion in 'Mechanics Garage' started by KC-10 FE, Oct 30, 2016.
  1. KC-10 FE
    KC-10 FE New Member
    Greetings everybody. I haven't been here in ages.
    After 17 years, my stator finally burned out. I AM NOT wanting to rehash all the electrical posts. I have 1 question.
    I'm getting a new stator with heavier coils & larger output wire from customrewind.com & the RR from Roadstercycle.com.
    The question: I installed the VFR harness from wiremybike.com 4 years ago. Should I remove it or not?
    KC-10 FE out...
  2. 34468 Randy
    Wow! Was Jesus at your side when you came back/
    Sorry. Don't have an answer for you.
  3. mello dude
    Romania
    My 2 cents is to shitcan it. I have seen threads where it caused problems. -- If you wire direct (2nd graphic) like the roadstercycle recommends you will be fine. (Ignore the compufire inference, replace with FH020AA)
  4. KC-10 FE
    KC-10 FE New Member
    So the OEM connector is simply not used & tucked away?
    I'm getting the Shindengen FH020AA, the 30 amp CB & the LED Voltage monitor.
    KC-10 FE out...
  5. mello dude
    Romania
    Yes - this guy - I sealed it up like the 2nd picture. Just used some 1 inch schrink tube and stuff it in the bike.
    Also - note for your stator - get extra long leads that will go all the way to the R/R. That way you can just use the Standard stator connectors that are supplied from Roadstercycle and go direct to the R/R. Much cleaner.
    Lastly the 3 pic is at tip for the positive lead connection. Large HD eyelet and a good way to the battery. If you want you could reuse the fuse box off the VFRness. Its a beefy piece with 8 gauge wire on it. (last pic)
  6. RVFR
    Well Hello Hello.. Good to hear you're still hanging. Yep, follow Mellos lead here.
  7. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    If you are getting a high output stator, you should go with the series SH847 rr from roadstercycle.
  8. KC-10 FE
    KC-10 FE New Member
    I spoke to the guy at Custom Rewind. He said I'll see no real difference in output & he doesn't recommend using larger coils unless I need extra output. So, I'm going with a stock rebuild. Roadster is selling me their super kit & Jack said it's literally stupid simple to install. He said if I know my way around my bike, the entire install should take 30 min.
    I guess I cant complain, Yellow No. 2 has only let me down twice in 17 years. Truly a faithful steed.
    KC-10 FE out...
