sticky throttle
Discussion in 'Mechanics Garage' started by SUPERSTARDJ01, May 8, 2014.
  1. SUPERSTARDJ01
    SUPERSTARDJ01 New Member
    Milton Keynes, United Kingdom
    Hi all,
    Just got an 02 vfr800 vtec and have noticed when the throttle is opened fully then when trying to close it sticks, I couldn't remove the right hand switch gear fully to properly grease the cables so jst squirted some in the cable hole and opened and closed the cable, it feels like it not the cable but something under the airbox.
    Ideas?
    Cheers
  2. ZEN biker
    ZEN biker New Member
    Assiniboia, SK
    There is some cross linkage on the left side. That may need some attention. The return spring is there as well. Make sure it is working correctly. There are two cables to the 6th gen throttle, make sure both are free and not sticking.
    Cheers
  3. Scubalong
    Check on the grip as well make sure no rubbing on the weight end bar.
  4. squirrelman
    Has the bike been worked on lately ? One common cause of sticking is improperly routed cables or too little freeplay in cables.
  5. SUPERSTARDJ01
    all checked and ok, i may lift the airbox and spray some carb cleaner in the butterfly valve things.
  6. ZEN biker
    Assiniboia, SK
    Use spray on litnum grease on the linkages after you clean them with carb cleaner. Brake clean works great too.
    Good substitute for litnum is jig-loo spray lube. Dont bother with wd-40 or other oil based lubes, you will just be cleaning it again in 500 miles.
  7. SUPERSTARDJ01
    ok, so I've taken the cables off and lubed them inside, lubed all linkages the cables attach to, checked the routing and cleaned and oiled the butterfly vavles, also lube the throttle grip, at stand still the throttle doesn't stick open but when opened full on the move it sticks and holds itself open.
    Ideas?
  8. nearfreezing
    nearfreezing New Member
    Worcester, MA
    Try isolating the problem to either the cables/throttle control or the throttle bodies. Disconnect the throttle cables from the throttle body and open the butterfly valves all the way by hand. Do the butterfly valves still stick open? If so, there still a problem with the throttle bodies. If the butterfly valves snap shut, the problem is isolated to the cables.
