Strange Development just occured....
Discussion in 'Mechanics Garage' started by daveyto, Apr 1, 2010.
  1. daveyto
    daveyto New Member
    Scarborough, Canada
    Funny....the rad fan is seized , the temp gauge dont work and the bike won't start now....
    Plenty of battery....
    What I mean is the starter motor wont even turn!!! But all lights are on???
    WTF???
  2. abner malidy
    abner malidy New Member
    mark it 8, dude
    ive seen many batteries that will charm the lights, but will not fire a bike.
    basically discharged to no-load potential.
    does it go click,click,click,click,click,click,click,click, real fast when you hit go?
    if so, your starter relay is probably good, but not enough batt
    temp gage- is it analog? if so, it wont move from stop unless warm
    fan- is the engine hot enough to trigger fan? at least about 200F or so?
    or have you tried to jump the switch and it still wont turn?
  3. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    Stupid question but is the bike in neutral when you are trying to start it?
    Rollin
  4. reg71
    Sikeston, MO
    isn't there a sidestand switch that can go out and cause that, too? it seems like that happened to me on a yamaha I used to have. Nothing to do with radiator or fan, though, but the starting thing...
    also I might have flipped your kill switch off when I rolled past you at a stoplight... better check...
  5. daveyto
    daveyto New Member
    Scarborough, Canada
    Yes it is! I am mystified here?
  6. daveyto
    daveyto New Member
    Scarborough, Canada
    Ithe killswitch is fine...the starter doesnt move and all the lights are on???
  7. daveyto
    daveyto New Member
    Scarborough, Canada
    the fan is seized and needs to be replaced
  8. daveyto
    daveyto New Member
    Scarborough, Canada
    Turns out the battery was low like you said....I am charging it right now
    I guess the battery doesn't charge while the bike is idling?
  9. daveyto
    daveyto New Member
    Scarborough, Canada
    BTW....Thanks
  10. nozzle
    nozzle New Member
    Southern Maryland
    May not be charging enough... or the Regulator is toasting.
  11. elwray
    elwray New Member
    Central NJ
    No it's not like a car... I believe you have to be cruising on the bike for a good 10 minutes at least before you're going to start putting some juice back into the battery..
  12. daveyto
    daveyto New Member
    Scarborough, Canada
    regulator is supposedly new...according to the ex dumbass that owned the bike...said it was his baby....its become the bane of my existence
  13. betarace
    betarace New Member
    Middleburg, VA
    battery tender, well worth the $35... I am still on my orig battery and R/R since 1992. 18 years and still rockin
  14. elwray
    elwray New Member
    Central NJ
    +1.... most of them even come with the "hardwire" pigtails you can run outside of the fairing. Makes it a simple 2-second process to plug it in when you get home.
  15. betarace
    betarace New Member
    Middleburg, VA
    si, si and I have a powered tank bag. I unplug from the charger and plug into my bag. Run GPS, radar detector and phone charger off of it.
  16. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    I have an extra radiator fan that I could sell you if you need it. Send me a PM if you are interested.
    Rollin
  17. tinkerinWstuff
    Sounds like you have Gremlins in your garage and the previous owner did not.
    Harder on that rectifier trying to charge a low battery.
    Anyone know where to get more pigtails for the tender? I went into radioshack and the chick thought I was nuts. Started showing me phone cords.
  18. elwray
    elwray New Member
    Central NJ
    I actually saw some at the local motorcycle shop.... weren't super expensive either....
  19. tinkerinWstuff
    You saw Gremlins? Not taking my bike there.
  20. elwray
    elwray New Member
    Central NJ
    .....:doh: lol
