Stuck brake light
Discussion in 'Mechanics Garage' started by lamboid, Mar 28, 2010.
  1. lamboid
    lamboid New Member
    after a winter in the garage, my old '87 vfr750 (FH in the UK) is almost ready to stretch her legs again.
    One thing stopping is the brake light being stuck on.
    Before I pull out the spanners, can anyone offer any advice?
    Having a baby means I don't get enough time to look after the bike so going in prepared is best!!
    thanks
    Matt
    Front or rear ??
    Take off the switch at rear and soak it in solvent like kerosene (diesel fuel).
  3. karazy
    karazy New Member
    Halifax, Nova Scotia, Canada
    There are only two switches and one of them is probably sticking closed. I would think that the rear one would be the easiest to disconnect, to isolate which one is the culprit. Hopefully just a little action or cleaning will fix it.
    :crazy:
  4. squirrelman
    As Karazy sez, start with the rear switch: it's usually at fault when light stays on, while front switch fails most often by not switching on at all.....
  5. lamboid
    lamboid New Member
    thank you all.
    now where is the rear switch then?!!
  6. karazy
    karazy New Member
    It's that black, plastic, threaded thingy, just aft and above of the pedal. It allows you to adjust when the brake light will come on.
  7. PAFirefighter11
    PAFirefighter11 New Member
    Southeast PA / Brick, NJ
    Do I typically need to purchase a new switch if this is the case? Where is it located? Just purchased my bike and only the foot brake actuates the brake light. Thanks!
  8. karazy
    karazy New Member
    It might just need to be cleaned. It's a little microswitch on the lever, below the master cylinder.
  9. PAFirefighter11
    Precisely the info I needed. Thank you!
