Greetings all, Just recently pulled the 1998 VFR800 out of storage and noticed two things, first the neutral indicator is no longer working AND the coolant temp readout reads "--", even after having been driven. Both these items were working when it was pulled out of storage, but then just stopped at the same time. Page 19-3 of the repair manual, under Thermosensor/digital coolant guage, states: --------------------------- Turn the ignition switch ON, but the digital coolant temperature guage does not indicate - replace the sub fuse when the neutral indicator and side stand indicator does not operate --------------------------- This says to me that IF the temp guage AND the neutral inidcator both are not working that the sub fuse should be checked. The question is: Where is this sub fuse?? There is no other mention to it's location in the Repair manual.
