Suggestions for sprocket chain replacement reasonable price
Discussion in 'Mechanics Garage' started by 5 speed, Dec 25, 2008.
  1. 5 speed
    5 speed New Member
    Need to replace the set, completely worn out. I have seen some O ring sets on the internet for 123.00. Sounds pretty reasonable and an RK set for 143.00 on ebay. Any other suggestions, its an 02 that I have. Does anyone know the number of links required? I found a set with 110 and one with 120 which was more but if I dont need it, whats the point? I assume I can use a normal chain breaker to get the old one off, yes? Assuming the new will come with a master link.
    Is there anything else I need to know to get the old off? I see there is a cover with all kinds of plumbing over the countershaft, do I need a gasket or anything as I prepare to replace it?
    Thanks guys for any info you can share!!
    how many miles on the chain now?
    the whole set-up can't be found for less than about $ 170.
    here's your chance to re-gear your ratios if u like
    use steel, not alloy rear sprocket
    best to cut new chain with adjuster rolled to a forward position so later wear can be taken up
    small gasket on cover likely won't be damaged
  3. NorcalBoy
    Model: VFR 800 02-04
    OEM Gearing is 43-16
    Number of links: 110
    Stock size: 530
    Rear Sprockets can be found from 43-45
    Front Sprockets can be found from 15-17
    You shouldn't need anything other than the chain and sprockets.
  4. 5 speed
    5 speed New Member
    guys thanks for the replys. I have 18K on the set up now. I dont think I will change the ratio as everything is a compromise so if I improved one area its going to make another worse.
    I saw on ebay an RK kit for 143.00, guess that was a good deal. one of my local Honda dealers told me he couldnt find a kit as the one he found only had 108 links? so priced separately he wanted 193.00. yea, no thanks I know I can do better,
    anyone have a line on where I can get the right kit? I just need a middle of the road quality, nothing fancy unless its close to the same price and then I want a gold chain. Dont need an X chain, good old o ring with steel sprockets will be fine. This thing isnt making a ton of horsepower, I dont dump the clutch on it so driveline shock should be minimal.
  5. betarace
    betarace New Member
    Middleburg, VA
