SuperTech oil filters are back at Walmart
Discussion in 'Mechanics Garage' started by Lint, Apr 20, 2016.
  1. Lint
    Lint Member
    Simi Valley, Ca.
    I stopped in to grab some Rotella 6 and up on the top shelf, there they are, again! $2.84. With the gallon of Rotella T6, my oil change cost all of $26.02!
  2. BWeiss
    BWeiss Johnny Partseed
    Rancho Cordova, Ca
    Do you happen to know if they're still made by the same supplier as before? Weren't they made by Champion or something like that?
  3. sunofwolf
    sunofwolf New Member
    P1010087.jpg those filters are crap-the steel shell is very thin, I use napa platinum and rt.castrol
    Nothing but the best for the VFR King,
  4. Lint
    Lint Member
    Simi Valley, Ca.
    The box says that their 75% made in the USA, whatever that means. Only 95% filtration down to 29 microns. Don't know if that's good or crap tho.
  5. Suraj
    Suraj New Member
    Pittsburgh
    Saw those on my last oil change a month ago. Then thought I change oil on my bike once/twice a year, so additional $4 on a pureone is worth it to keep the engine cleaner, it says 99.9% efficient. Worth the extra money IMO.
  6. sunofwolf
    that is not good, ST are cheap crap. a napa platinum goes for $9 on sale-uses a high tech Full synthetic filter-and can hold a lot of dirt too-also flows better,
    the one I use is bigger than stock size-removed carbon canister -gave me a lot of extra room, . t6 oil does work ok , but castrol rt is made for MC and I would trust it more too.
  7. sunofwolf
    the one thing I would question on pureone-is oil flow rate may not be that good.
  8. Marrib
    Marrib Insider
    Phx, AZ
    I use a wix filter. I get them discounted.
  9. Lint
    Lint Member
    Simi Valley, Ca.
    Yeah, I may exchange it. The whole 95% thing is a disconcerting.
  10. sunofwolf
    ST filters are just average barley , go with a Napa Platinum. I have bought all these three filters, you can actually see the differences. Get the best oil filter.
  11. OOTV
    OOTV Member
  12. sunofwolf
    outdated material
  13. Lint
    Lint Member
    Simi Valley, Ca.
    I bought a Bosch filter instead.
  14. sunofwolf
    bosch is better, I put in 3.25 qts, know the book says 3.3 but when I add that its too much, I bet it is slightly over filled.
  15. Gator
    Gator Member
    OEM for me. I think Honda knows the exact pressure the valve is supposed to operate at. Sure others may work but are they the right flow? Especially anything designed for cars or trucks.
  16. sunofwolf
    I doubt that- notice the wagner blub on the plate light, sometimes Honda goes cheap. It's up to the owner to fix flaws
  17. James Bond
    James Bond Member
    Dixie
    Agree on that. We buy a Honda but their filters aren't good enough? A tank of gas costs more than a filter by far.
  18. sunofwolf
    It really isn't easy to change the oil filter and put 3.3 qts in without out over filling it. This oil change I got it close to perfect-maybe a tiny under filled. I put it 3.25 qts-all most perfect by the sight glass on a level road. Bare in mind there is still some oil not draining. The best oil filters that work pure 1 and napa platinum-my favorite. Seems to be a shortage of motorcycle oils that work well- I choose Castrol rt, it comes in 05-40 and 10-40 and 10-50. The fasteners suk . it took me three hour's because of the fairings, but I feel happy it was done excellent.
