Support for Fork Removal
Discussion in '5th Generation 1998-2001' started by HellFishTat, Jul 2, 2017.
  1. HellFishTat
    HellFishTat New Member
    Raleigh, NC
    What do you use to support the front of the bike when you remove the forks?
    I haven't done this before, and have a set of Daugherty cartridges I'd like to install (finished the 929 shock conversion earlier today) before I head to the mountains in 2 weeks.
  2. vegaquark
    vegaquark New Member
    Spain
    Spain
    I use a piece of wood stucked below the oil cooler on the front head. It must be the exact lenght
  3. vegaquark
    Spain
    Spain
    Somthing like this... :)
  4. vegaquark
    Spain
    Spain
    This way... I'm doing it now to clean the front wheel :)
  5. GreginDenver
    GreginDenver New Member
    Denver, Colorado
    I built a rolling support out of scrap lumber and cheap Harbor Frieght furniture dollys. You can see pictures of it if you go through my thread "Refurbishing my '99 5th Gen".
  6. HellFishTat
    Raleigh, NC
    I like that!
    I ended up hanging it from the top triple clamp from my 2nd floor joists in the garage., but may cut a piece of lumber and do that instead.
  7. Terry Smith
    I have previously been using a block of lumber under the headers. Just recently, I had to replace a front exhaust gasket. Coincidence? The best solution is a head lift like this:
  8. vegaquark
    Spain
    Spain
    Hmmm thats a vtr... Intrusion!
  9. Terry Smith
    True enough, but they are a bit related, similar frame and radiators AND the same colour! I don't use the head stand on my VFR because I have a voltmeter mounted through the steering stem, and the wires would get cut by the stand pin. Not much of an excuse I know.
    The head stand is a truly great piece of work, cheap and very easy to deploy, and super stable.
  10. OOTV
    OOTV Member
    Before I bought my Pit Bull headlift and ABBA Skylift stands, I inserted two eyelet bolts into the ceiling joist of my garage about a foot or two apart and then use a ratchet style tie down that has a long strap and looped that under the frame of the bike just behind the steering stem, attaching the two hook ends to the ceiling eyelets. Then I put the bike on the center stand use the ratchet to lift the front end off the ground. This method has one big advantage, no way to accidentally knock the bike off of the support mechanism.
  11. vegaquark
    Spain
    Spain
    Yes... All fancy but if you've got to diassembly the triple clamp or the frame, my cheap as f... method works like gold
  12. ksoholm
    ksoholm New Member
  13. vegaquark
    Spain
    Spain
    Yes... That stand is great for minor operations on forks, front tire and brakes, but if you have to remove the steering bearings from the frame, you cant. Or the frame completely as i had to do... Without fairings for peace of mind i used an old tire beneath the engine and this same peace of wood with no issues at all. Is just a matter of knowing what you are doing and being careful.
