Suspension setup help
Discussion in 'Mechanics Garage' started by Rubo, May 16, 2009.
  1. Rubo
    Rubo New Member
    I just bought 1998 VFR (started a thread on general section)and I noticed that the bike is much harder to make it turn specially if the turn has more lean. It is just not neutral ,the front I suspect needs to be lowered but I am wondering if I can make it turn faster without lowering the forks.
    Thanks guys:thumbsup:
  2. betarace
    betarace New Member
    Middleburg, VA
    this may help
  3. squirrelman
    Obviously, you've checked the condition and pressure (with an accurate gauge) of the tyres??
    checked or changed fork oil and steering bearings?
  4. Rubo
    Rubo New Member
    I'll check the tires.Interesting that I added more pre load on rear and its turning in lot faster and easier.
    I guess I stumbled on solution blindly.
  5. Rubo
    Rubo New Member
    Even thought I thanked many times my posts says zero.How do you thank that it counts?
  6. squirrelman
    IF that fork oil hasn't been changed in a few seasons ......it may be dirty and done wo' out !
    measure the springs when you remove fork caps to see that they haven't sagged below the limits you will find listed in the service manual.
