Swing arm Dimensions
Discussion in '3rd & 4th Generation 1990-1997' started by Karkarov, Aug 19, 2017.
  1. Karkarov
    Karkarov New Member
    Austria
    Hi !
    I am from Austria nd i got a little Problem. I bought the wrong swingarm for my Bike. I got a Yamaha Bike were I am trying to fit in a VFR 750 1993 Swing arm. The Problem now is that the Bush I made to fit in the SSS is to big. i found out after a Week of searching that the Swing Arm I got the Bush for is from the 3rd Gen and the Bush was made for the 4th Gen.
    I found out that everything else is the same only the width of it changed. From 237mm to 225mm so now my question is if anyone can help me out. It will need both swing arms so that when you align them if 6mm on both sides will clear everything or if i have to buy the other SSS !
    Please ask if you have further questions !
    Hope someone can Help me !
    Greetings from Autria !
  2. Magoo47
    Magoo47 New Member
    It would possible but 6mm run out shouldn't upset the handling
