Symtoms of pair valves failing?
Discussion in '5th Generation 1998-2001' started by steven113, Nov 25, 2009.
  1. steven113
    steven113 New Member
    Pensacola FL
    I have been experiencing popping from my exaust on downshifting lately and occasionaly at a steady rate of rpm just off the throttle and wandering if this might be symptoms of leakage of the pair valve system or guidence as to where else I should start looking for such a problem. No codes are being displayed and other than the noise everything is running 100%
  2. TOE CUTTER
    That sounds like a long hunt.Good luck.
  3. Jollyhart
    Jollyhart New Member
    Air leak inlet side?Or maybe air getting in the top of the exhaust??
  4. steven113
    Pensacola FL
    Follow up... I blocked of the pair valves with a plate kit sold on ebay and the popping is completely gone. Problem solved :)
