That Green Gasket
Discussion in 'Mechanics Garage' started by KizerSosay, Mar 21, 2016.
  1. KizerSosay
    KizerSosay New Member
    Im pissed. What the hell can I use to get that green gasket off? I'm trying to get it off my stator cover? That crap is hard to clean off. Got that shit on the engine case side too. Its a bitch to get at.
  2. redwing750
    redwing750 New Member
    Buffalo NY
    Try either paint stripper or lighter fluid if you have, possibly acetone also.
  3. KizerSosay
    Ah yes' the mighty acetone...that should do it. I have some in my shop box. I was going to say the green stuff reminded me of super glue. Thanks
  4. zoom-zoom
    zoom-zoom Member
    BC, Canada
    I used acetone on my clutch cover gasket last year when I installed a new cover and it worked very well. Used a single edge razor blade to scrape most of the gasket off, then used a rag and liberally dabbed the acetone over the areas with some gasket residue left over and then used the razor blade to gently scrape off the remains.
  5. KizerSosay
    Klunker
    After 2hrs of scraping I got the gasket clean. New stator, new r/r, new battery installed and still no charging at all. Runs on battery fine until it dies. I'm starting to not like this pos. These mf'ers cost some bucks to keep going compared to a car. And I'm doing all the labor myself. Tires, chain, sprockets, stator, r/r, battery, brake pads fluid change, all in first 23k miles. Its sitting there not even road worthy. Haven't even checked the valves yet. IT'S A MONEY PITT.:grumpy:
  6. TOE CUTTER
    Now hold on big guy, it is a very simple system and some little thing must have been over looked. No need to get angry with the bike. We are here for you both. Can you give us a little more insight to what has happened to this point? Maybe your location?
  7. KizerSosay
    I know right...I just had a couple brews and cooled off now. I'm in Gettysburg PA. Long story short the battery won't charge after testing and replacing my r/r, stator and battery. All new and still no charging. What is there left between the r/r and battery that could stop volts to the battery? Battery is 12.6v at rest and 12.1v running. Everything else tests in spec.
  8. TOE CUTTER
    R/R and stator are new from Honda or another brand?
  9. KizerSosay
    New Rick's srator and r/r or factory Honda stator with upgraded Honda r/r. Both give the same readings with 12.1v at battery running.
    Is there a inline fuse somewhere between the batt an r/r?
  10. Terry Smith
    You mean like this (from the service manual)
  11. bigbadbass
    bigbadbass New Member
    NEW YORK
    break it down to test components
    start with a stator output test (not connected to rr), if it passes then output at regulator connections (not yet connected to battery)
    double and triple check integrity of your grounds
  12. KizerSosay
    Stator is 61v at 5krpm. R/r output is 1v at 5krpm. I think my brand new r/r is a dud.
  13. superpsu
    superpsu New Member
    Cortland, NY
    Hey there buddy,
    I had the same problem with my 2002 VFR VTEC. My connector between the stator and voltage R/R was fried. I first ordered the stator and R/R after buying a new battery. I thought everything was good, but the bike died on me shortly after taking it for a little ride. What you need to do first is test the stator at the connector. If those readings are correct, then it is most like a faulty R/R. The only way to test it is by doing a diode check on the R/R. Do a search on youtube for testing the stator and R/R. I would not be surprised if the R/R is the cause of your problem. I hope this helps.
  14. redwing750
    Buffalo NY
