That Moment When All The Hard Word Finally Pays Off. Rapid Bike Racing Now Available!
Discussion in 'Mechanics Garage' started by CandyRedRC46, Sep 25, 2014.
  1. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    The Rapid Bike Racing Kit is now in production and available for all VFR800 VTEC models. Confirmation of 5th and 6th gen use will be made later on. The Rapid Bike Racing features self mapping through the factory O2 sensors. It has full ignition advancing control, Advanced 18 way adjustable Quick shifter control, Engine braking adjustment and RPM limiter extension of 1000 RPMs if requested.
    http://rapidbike.us/t/categories/honda
    [/url] vfr (1).jpg
  2. metallyguitarded
    metallyguitarded New Member
    San Diego, CA
    I'm excited and I don't even know what that all means!
  3. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
  4. carlgustav
    carlgustav New Member
    Heart of Dixie
    Now that's funny, reminds me of an early Jessica Simpson commercial about HD TVs ... :biggrin1:
    ACE
  5. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    here are the features
  6. Arnzinator
    Arnzinator New Member
    Central Massachusetts
    Curious. How does this system control engine braking? Does it need data from a wheel speed sensor to do so or does it just look at engine load, rpm & throttle position?
  7. xorbe
    xorbe New Member
    San Jose, CA
    I'm going to guess you get to choose between full DFCO to no DFCO at all. (dynamic fuel cut-off)
  8. kennybobby
    kennybobby New Member
    Morning Wood, it's all Good! That moment when all that Hard Wood pays off...
  9. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    That's what I am thinking. It just bypasses the fuel cut by taking in data from the o2 sensors and adding fuel as necessary even while at 0% throttle and high rpms. I will find out for certain tomorrow.
  10. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Ok I just talked to Yaman at Cycle Pro/ Rapid Bike. He explained the engine braking adjustment feature of the Rapid Bike Racing Module to me in detail. Basically it is a fuel cut eliminator of sorts. It does not utilize the o2 sensors though. What it does is it allows you to add fuel to the 0% throttle column at all rpms (no blocked cells like power commander or bazzaz). It is done by feel, just add some fuel, go for a ride and adjust as necessary. Once you get the 0% throttle higher rpm fueling adjusted to your liking, what you get is a bike that is much less abrupt in the on/off throttle transition at higher rpms. This is something that I do not believe can be accomplished with power commanders and bazzaz units, as they only add or subtract based on a percentage i.e. 10% of zero fuel is still zero fuel.
  11. Badbilly
    Did Marge and Homer have another kid?
  12. TOE CUTTER
    Because I love CandyRed I must request the mods make a correction to the thread title purty please.
  13. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Lol ugh how did I manage to mess up that title....
    love you too toe cutter :p
  14. carlgustav
    Heart of Dixie
    Maybe, considering that blonde is about as smart as Bart ... nicer to look at though :boobies3: ...
    ACE
  15. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Before and after Rapid Bike racing dynos of a 100% stock 2003 VFR800, tuned using the 2 factory narrowband o2 sensors. Keep in mind that this is with no other mods, not even a slip on or air filter. The improvements should be much greater on modified bikes or in the case of tuning each cylinder independently with four o2 sensors. [​IMG][​IMG][​IMG]
    That is before and after at 100%, 23% and 13% throttle positions. On the 13% throttle you can see the dramatic breakdown of just fuel corrections alone and then the added benefit of tuning the ignition map on top of the fuel map.
