The big Oil Debate
Discussion in '3rd & 4th Generation 1990-1997' started by TTavenierIII, Oct 4, 2010.
  1. TTavenierIII
    TTavenierIII New Member
    Kissimmee, Fl
    ok so am doing new clutches and steels on my bike. im using ebc kevlar clutches with harder springs because i want more of a grab. but i got a big question. i would like to run synthetic oil but i was told with this bike its not recomended because it will cause slippage of the clutches. does anyone have and ideas or tips. thanks in advanced.
  2. crustyrider
    crustyrider New Member
    North Country, New York
    :pop2: ..........
  3. bitterpil
    bitterpil New Member
    Northern Virginia
    There about a million and one oil threads on this site alone that deal with the great oil debate. Pop some corn, get a soda an stay in for the evening and read through them. You will find it is mostly opinion based on some sort of fact somewhere. There will be some truth in there you just have to wade in and find it.
    Basically to answer your question, our bikes use the engine oil to lubricate the engine and share this lubrication with the clutch. It isn't the oil that Can cause the issue with the clutch but the additives in the oil. On the rear of the oil container you should find an API lable it is a circle. If is states in the bottom half of the circle "Energy Conserving" then you should probably stay away from it. Molybdenum is one one of the additives if not the major one of concern with wet clutches.
    All oil has its additive package. The intended use dictates how much and which additives are added to a specific oil. Diesel, gas engine, motorcycle or heavy truck etc.
    So your problem isnt synthetic vs dino.
  4. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    Damn, first you tell him to go look, then you give him the answer, what fun is that BP..............
  5. bitterpil
    Northern Virginia
    I suk like that.
  6. mrvfr
    mrvfr Banned
    I will say,,, with my new truck that dio oil seems to loose its effectiveness after about 2k miles and my gas mileage goes down.
  7. NorcalBoy
    It's not the big oil debate, it's the big people debating oil........
  8. crustyrider
    yep they are masterdebaters
  9. tinkerinWstuff
    if we'd televise the debates, then we'd really be able to know who won.
  10. TOE CUTTER
    I would not give it another thought and run your new clutch in the oil of your choice. You will be fine.
  11. tinkerinWstuff
    Sounds reasonable enough.
    /debate
    But if the debate were televised, you'd see TOE sweating his ass off under the lights.
  12. John451
    John451 Member
    Not part of this debate but with 27K miles on my '99 went from Motul Moto 5100 Semi Synthetic oil to a same priced FUCHS Silkolene Moto full Synthetic Comp 4 and even though only had 2500miles on the Motul was supprised how much smoother my VFRs engine felt on the Fuchs Synthetic on a recent road trip though not sure if all Synthetic moto oils feel immediately smoother than Semi Synthetic.
    Any opinions ?
