thinking about getting a vfr???
Discussion in 'General VFR Discussions' started by 91 vfr, Mar 21, 2011.
  1. 91 vfr
    91 vfr New Member
    WI
    So i am thinking of getting a 91 vfr750f that is priced for $2150. has 43,327 miles on it? is it worth it? i am going to talk they guy down from 2100 though but is this a reliable, powerful, good bike to own even with that many miles? what are things i should look for on one of these bikes when buying? all help would be much appriciated.
  2. 34468 Randy
    I wouldn't be worried about that mileage. That is peanuts. But two grand for a 20 year old bike seems incredibly high to me. Incredibly high. I think other will chip in here and agree. But if that is what you want, go get it and ride the beach like a cheap ho and put her away driven and wet.
  3. 91 vfr
    91 vfr New Member
    WI
    well i KBB'd it and it is bluebooked at 1900? so idk. guy say's it needs nothing for summer ready to ride. im gonna see if i can get him to $1700. but he say's he doesn't need to sell it so idk?
  4. bitterpil
    bitterpil New Member
    Northern Virginia
    $1800-1900 check tires oil brake pads anything thst could give yo a discount.
  5. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    Price seems reasonable assuming there is no major body damage. Be forewarned that parts are becoming difficult to find for these older bikes and a single minor drop could easily cause as much damage as the bike is worth. I would highly advise checking the condition of the fairing tabs because they were poorly designed and break quite easily especially with the aged brittle plastics. It doesn't help that plastic for 3rd Gens is very expensive to replace and very difficult to find. Also check to make sure the OEM R/R (regulator/rectifier) has been changed since they are notorious for going bad. The owner shouldn't have a problem removing the fairings for you prior to you coming if there is nothing to hide. Last but not least don't forget to make sure the key works for both the ignition as well as the seat lock.
    Rollin
  6. TOE CUTTER
    I am the worst to chime in on this.......I LOVE THE GEN THREE...... If it is a clean bike all other things can be worked oot. It is truely the best of the VFR family. Miles are not an issue, clean body work is everthing. Sounds like a good deal for a clean bike, post a pic if you can.
  7. tweak740
    tweak740 New Member
    got mine for 1400 with 32,xxxx miles in good shape needed tune up brake pads and front tire
  8. 91 vfr
    91 vfr New Member
    WI
    Thanks for the replies. I will be looking at it in a day or 2 depending on weather, don't wanna buy it without a test ride. I will post pics if all is good and I get it.
  9. tinkerinWstuff
    just but it already
  10. 91 vfr
    91 vfr New Member
    WI
    So I'm looking at it on thurs when the snow stops and I was wondering what are the specs of the vfr750? Other than the stuff I found online. Is the 100bhp at the crank or rear wheel? Is this a fast bike, (compared to my 91 yamaha fzr 600)? Is it a torque monster? What are the mod's if any that can be done, jet kit, coil upgrade, etc? How will it hold up to 600's of the early 90's or to newer bikes? I know it won't beat newer bikes but will it be left in the dust or put up a fight? Just curious about the bike before I buy it!! :D
  11. tinkerinWstuff
  12. 91 vfr
    91 vfr New Member
    WI
    Any way for me to tell if this bike is a California model??
  13. tinkerinWstuff
    VIN number
    VFR VIN decoder VINs
    And according to this person's data, the 1st 403 bikes of the 1991 model year were California model VFR750 (RC36) Model Info Any bike with a VIN ending 404 or higher should be 49 states.
    Further verified by looking at carb numbers and engine case numbers and emissions equipment installed. At the end of the day, who knows what engine is installed in a 20 year old bike.
  14. 91 vfr
    91 vfr New Member
    WI
    One more question. Does the exhaust come out on the right or left side of the bike stock? And does it really matter?
  15. tinkerinWstuff
    Right side stock.
  16. 91 vfr
    91 vfr New Member
    WI
    So looked at that vfr today and is not as good ad I thought. Needs front tire, fork seals, left fairing cracked and fairing behind front tire (v-shaped fairing) isn't bolted up and cracked and front blinkers are loose, and missingsome of the inner gauge fairing covers and the guy wouldn't go below 2000. I told him I woul only give him 1600. Is it worth it at that price ($1600) or not?
  17. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    I think you can find one in better condtion for the same asking price if you are patient. $1600 would be a good deal assuming nothing mechanically wrong.
    Rollin
  18. 91 vfr
    91 vfr New Member
    WI
    Well talked the guy down to $1500. Im goin to get it pending a test ride and that it shifts and rides good. I did notice that it already has the VR upgrade done to it. Anything I should know about how it shifts or rides before I ride it?? Shifts hard in a gear?, pulls to the right,? Any of that stuff?? Thanks in advance.
  19. 91 vfr
    91 vfr New Member
    WI
    I did notice the last three numbers in the vin are like 298 or something in the 200's.
