Thinking of buying a 1993 VFR 750 F
Discussion in '3rd & 4th Generation 1990-1997' started by Exulatus, Jun 11, 2016.
  1. Exulatus
    Exulatus New Member
    I am considering buying a 1993 VFR, its done 100.000 km (62.000 miles) shud i be on the lookout for any common problems or anything special?
    Thanks in advance.
  2. ridervfr
    pull seat off, look on the right side of the bike where the imfamous r/r is, if you can remove rear side covers, that will give you a good birds-eye-view of the condition of the plug (when you unplug it) the owner may have up-graded the r/r already though. Near the battery is your 30 amp starter relay, those sometimes burn out, on the right side of the bike, if you can remove the mid-fairing, (pretty easy with the 1/4 turn d-zus fasteners) and check out the three yellow plug, thats the stator wire that goes to the r/r via harness, these sometimes burn out, if they do, and any of the wires touch, its curtains for the stator. Other than that, condition condition condition. Keep us posted
    VOLBEAT RULES :rockband: :drummer: :guitar:
