This is probably going to seem like a ridiculous question...
Discussion in '1st & 2nd Generation 1983-1989' started by Rusty_Spoons, Apr 25, 2016.
  1. Rusty_Spoons
    Rusty_Spoons New Member
    Southern New Jersey
    There are two lines that come off the petcock. One goes to the fuel filter and then the fuel pump and the other one goes to... Where? I just purchased the bike and the second line coming off the petcock was disconnected when I bought it. The manual is no help.
  2. Terry Smith
    I'm not specifically familiar with the VF500, but my VTR1000 petcock has a vacuum shut-off so the fuel can't flow with the engine off. A small vacuum line from the petcock connects to a port tapped into the the side of one of the engine air inlets, between the carb and the cylinder head. The vacuum signal moves a diaphragm in the petcock that opens a valve to let the fuel flow. These are a source of problems on older bikes as the diaphragm can tear or the valve stick shut, but they are easy enough to fix with new parts.
  3. squirrelman
    make sure the extra hose is plugged with a screw, bolt, or something or it may be leaking air into one cylinder and causing running problems.
  4. Rusty_Spoons
    Southern New Jersey
    Your hint gave me enough info to find where the vacuum line was supposed to go. the opening had been filled with a phillips head screw with the appropriate thread, so it was camouflaged as just another set or adjustment screw on the carb. Thanks for the help!
  5. Terry Smith
    Glad that helped, Spoons
