Throttle cable freeplay
Discussion in 'General VFR Discussions' started by 300shooter, Jun 17, 2008.
  1. 300shooter
    300shooter New Member
    armpit of ontario (Windsor)
    Anybody know if there is a way to adjust the freeplay on the throttle cable of an 03 vfr. I've got about 1/4 " roll in the grip before the throttle starts to engage, it's smooth so I don't think it's the cable,. Is this normal? It's kind of a pain in the butt on low speed corners, makes the throttle "choppy".
  2. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    Follow the throttle cables. There are adjustment nuts somewhere along the line, close to the throttle housing if I remember correctly.
  3. Ignorant Bystander
    Ignorant Bystander New Member
    Halifax, Nova Scotia
    There should be an adjuster immediately following the curved section coming out from under the handgrip, on one of the throttle cables. It's a thin hex-nut (locknut) butted up against a very long one (about 2" long). You need 2 wrenches, one for each nut.
    Put the wrenches on and back the locknut off (CCW) while holding the long barrel nut still with the other wrench. You can now spin the barrel nut CW to take some of the slack out of the throttle.
    Do this while the bike is running so you know if you're raising the idle any.
    When you get it where you like it, spin the locknut CW so it snugs against the barrel nut, then hold the barrel nut with 1 wrench while you tighten the locknut.
    I just did this the other day and it made a world of difference when trying to hold a steady slight throttle (no dead zone).
  4. ILVFR75
    ILVFR75 New Member
    Illinois
    good info here. thanks Ignorant Bystander! i've been having trouble w/ this as well. seems pretty easy to adjust. GOOD STUFF!
  5. Rustbucket
    Rustbucket New Member
    Factory specs for all bikes dictate more freeplay than I like. I prefer to have almost none. After you're done adjusting, turn the handlbars side to side and watch the tach/listen to the engine. If revs go up at all with the bars turned, you'll have to loosen the cable a bit.
    I go for the tightest I can get it without raising the idle or causing it to rev when turned the bars side to side (was a problem on my old bike, but not the VFR).
  6. malcster
    malcster New Member
    Bishop,CA USA
    2 Adjustments;minor is @ the lever,major @the throttle body,both on the cable.Freeplay(Honda specs)2-6mm.I go with what feels good,no specs on that bro
  7. 300shooter
    Thanks for that, feel kinda shtoopid now , didn't see the adjuster at first, thought it was more technical than that but it was just hard to see..
  8. Big_Panda
    Big_Panda New Member
    Simi Valley
    Over ten years later and still helping noobs like me! thanks guys if any of you are still on this forum!
