Throttle cable routing?
Discussion in '5th Generation 1998-2001' started by rmcdougal, Oct 6, 2013.
  1. rmcdougal
    rmcdougal New Member
    Fortuna CA
    I need to know where the cables are routed from the factory. I pulled mine out to change them a couple months ago and now do not remember where they went. Thanks
  2. TOE CUTTER
    There is a detailed set of pictures for such things in the front of the factory manual. Routing is critical for proper operation.
  3. rmcdougal
    Fortuna CA
    I completely forgot I had the download for that. thanks
  4. squirrelman
    Again, FSM rules, Bunky. :nelson: No Hanes or Clymer has the good cable routing info.
