Tiger Tiger
Discussion in 'Anything Goes' started by drewl, Nov 14, 2008.
  1. drewl
    drewl Insider
    Virginia Beach, Va
    Burning bright, in the forests of the night.
    it would be brighter if it had cbr 600 forks and desmosidici radial brakes.
  3. drewl
    drewl Insider
    Virginia Beach, Va
    One time at band camp...
  4. NorcalBoy
    but it is also much cooler because it has a gear driven final drive, which makes it much more visceral.
  5. drewl
    drewl Insider
    Virginia Beach, Va
    So there I was standing on the corner minding my own business when POW outta nowhere
    This guy throws a bottle of nitroglycerine at my feet(true story).
  6. NorcalBoy
    Please post a photo, I'm not sure if i understand the correct lcoation of the valve tappet main jet for that model.
  7. drewl
    drewl Insider
    Virginia Beach, Va
    So I grab the counter in anticipation of the impending loss of consciousness secondary to precipitous drop in blood pressure.
    It did not come, so I slowly opened my eyes.
  8. NorcalBoy
    oh, i think i see what you are saying, the height of the needle was affecting the float, so you went with the synthetic?
  9. btay67
    btay67 New Member
    Peculiar, Mo
    Okay, I'm lost on this thread. Is this just a thread to boost your post counts?
  10. btay67
    btay67 New Member
    Peculiar, Mo
    :rolleyes:If so.....I'm in, but it seems silly.
  11. NorcalBoy
    I'd be careful with how much boost you use as it might push out the head gasket at higher rpm's.
  12. drewl
    drewl Insider
    Virginia Beach, Va
    The counter check blocks flow to the flux capaciter. So you need to adjust flow to the bladder valve. I usually avoid carbs, but I do know that much.
  13. drewl
    drewl Insider
    Virginia Beach, Va
    Like a tornado sucking in anyone stupid enough to get too near.
  14. R.W.
    R.W. New Member
    Cloverdale CA.
  15. NorcalBoy
    your flux capacitor might not be functioning correctly because your R/R isn't feeling the connection between itself and the stator. you can use a tire gauge to balance the performance.
  16. drewl
    drewl Insider
    Virginia Beach, Va
    So I told Jeff, start an IV. Give me a shot of nubain and call the surgeon. Tell him it is me, he'll see me right away.
  17. 34468 Randy
    There is a new component out there to rplace the flux. Its called a circumpharnageaconnective.
  18. NorcalBoy
    yeah, but the petcock is vacuum operated, so you need to make sure that your air filter isn't clogged.
  19. NorcalBoy
    Do you have a website link you could post up for that?
  20. drewl
    drewl Insider
    Virginia Beach, Va
    The filter is a problem, but if you pull some power off the indicator light should go off and you can complete the mission. If need be you do the first leg part 135 then the return leg part 91.
    That is kind of twisting the rules, but not really.
