Tire pressure?
Discussion in 'Mechanics Garage' started by dsirl, Sep 28, 2006.
  1. dsirl
    dsirl New Member
    Boulder, CO
    I have searched the forums and have not been able to find a good consensus on tire pressure. I am running the Pilot Roads. Rear tire says 42psi, service manual says 42psi but I thought I have heard people say running in the 36psi range was better. Front is supposed to be 36 but I have heard 33psi. Any thoughts?
  2. reg71
    Sikeston, MO
    I run both tires around 32-35 psi and haven't had any problems. They stick well, wear pretty good, and that's about all I ask from my tires. Except I ask them to sing the star-spangled banner but none of them comply... cheap ass tire companies...
  3. Vlad Impaler
    Vlad Impaler New Member
    Indianapolis, Indiana
    IMHO
    36/42 per the stock rubber recommendation or 4 psi below the sidewall max load number is your best starting point.
    I have had the most confidence here and have had limited cupping, regardless of tire brand and age. I believe 33 psi on the front under hard braking may get you in trouble with cupping/scalloping, but I have no data so grains of salt are required.
  4. Vlad Impaler
    Wow Reg! 32 in the back!:eek: That's when things start feeling not-quite-right for me. But, hell, you may be warming up quicker than me out there in Cali, not to mention I am 6'1" and 218 lb on a heavier 1995.
    Looks like dsirl is going to have a hard time with a consensus the way this thread has started!:confused:
  5. dsirl
    dsirl New Member
    Boulder, CO
    Well, I rode about 200 miles today with 35/38 front/rear (or as well as I could tell with my tire pressure gauge). Felt pretty good; no slippage but I ran into some traffic in my favorite twisties so I didn't get to really wring it out.
    Funny, how I seem to trust the people on this forum more than Honda. Hmmm . . . :confused:
  6. Link
    Link New Member
    38 front 42 rear, no problems in the handling department.
  7. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    I am running about 35 front and rear. Seems to handle just fine. :thumb:
  8. Davidvfr
    Davidvfr New Member
    Concord West, NSW Australia
    I run what Honda recommends.
    36 front, 42 rear.
  9. RVFR
    33psi front and rear and have Pirelle diablos corsas. everything works real fine there.
  10. Spike
    Spike New Member
    I run 36/42 just fine. But you can also check the tire manufacturers website, some have PSI recomendations for their tires specific to models. As does Bridgestone on the BT020 that I run with. I that case they have the same recomendation as Honda, but they don't always.
    Start from there and play around with it a little. Up or lower the PSI a little, one tire at a time, do you like what it feels like? Play around with the PSI right around that #. Or do you hate it? then go the other way.
    It really only matters what you think/feel; not what any of us do. Your weight, suspension settings, road conditions, weather, will all affect what works best as a tire pressure for you. Start with stock, then go from there.
  11. troy
    troy New Member
    Westport Island Me.
    hey there, when my stock tires go bye bye, im gonna try pilot roads, on my superhawk i get 6-7k out of the rear and 9-10k out of the front this makes me wanna use them on my new vfr, does any one have input on this combo??
