Tire SIZE Question
Discussion in '1st & 2nd Generation 1983-1989' started by wleslie, Nov 7, 2006.
  1. wleslie
    wleslie New Member
    I have an '84 vf500 that I bought used and am doing a complete rebuild on. I need to replace both tires and I would like to get some thoughts on what sizes to go with. I want a combination that will give me good steering response and good grip. I do not feel the need to squeeze the largest size possible on the rear however. I will be running the factory wheels.
    I was also thinking about going one down on the front sprocket OR two up on the rear. This would give me a little more pull off the bottom. Again, I'm not worried about ultimate top speed.
    Any and all suggestions are appreciated.
  2. RVFR
  3. veefer800canuck
    veefer800canuck New Member
  4. wleslie
    wleslie New Member
    Thanks for the info. Can you tell me what the factory sizes are. My bike currently has a 100 on the front and a 130 on the rear.
  5. Spike
    Spike New Member
    depending on what shape the bike is in, and I can't remember how long ago they started this, but now a days, there is a sticker, usually on the left side of the swingarm, that lists the stock size, and even the OEM rubber options (which very well may no longer be availible)
    your owner's manual, if you have one, should also list the stock size
  6. veefer800canuck
    ooh, that 130 rear is going to be terrible on your narrow rear rim.
    too pinched in. :eek:
    here are the stock tire sizes:
    Front tyre dimensions: 100/90-16
    Rear tyre dimensions: 110/90-18
    you could probably use a 110/90-16 front and a 120/90-18 rear without any difficulty
    dunlop, bridgestone, pirelli, michelin and metzeler are all possibilities in these sizes.
  7. veefer800canuck
    as for the gearing, the little VF spins pretty fast at highway speeds, stock.
    if you gear it down you'll probably be searching for 7th gear on the open roads!
    i'd stay with the standard sprockets.
  8. wleslie
    wleslie New Member
    Thanks again for all the replies. They have been helpful. You're right about the 130 on the rear. It does look too big for the rim. I think I'll go with the 120 rear and 110 front. Probably Batlax BT45's.
    As for the gearing, I guess I'll go back stock with that. I've never ridden a vf500, so I didn't know what to expect in that area.
  9. reg71
    Sikeston, MO
    I have an 84 VF 500 also. It's a pretty quick little bike and mine is not even back in fighting trim. I'm having problems with a tapping noise and an unusualy amount of smoke once the bike warms up. I would tear the whole thing down and rebuild it, but I don't have a garage right now. I am thinking about taking it down to the basement to tearn it down and rebuild it, but it's kind of crowded down there already. My wife would kill me if I tore an engine down in the living room. :)
  10. RVFR
    FWIW at least stay with the 100 on the front, that's a pretty Critical area to mess with.
    Ha! Reg, go for it. would love to hear/read the stories behind this...:)
