Took my 1200 to the track
Discussion in '7th Generation 2010-Present' started by Elseebee, Jun 24, 2011.
  1. Elseebee
    Elseebee New Member
    Ever wonder what kind of quarter mile time you might get with your 1200? Me too, so I took mine to PIR and had a few runs.
    This is the first bike I've ever taken to the track, so I have a lot to learn.
    I've got some work to do on my 60ft times and my R/T.
    The 1st and 2nd gear bog is a real problem, so I'm going to pick up a PC, Juice Box, or wait for the Bazzaz (need to do more research to make an educated choice)
    I'm also shifting using the clutch, so if I just rock the throttle to unload the trans, I should be able to cut some time. My goal is to get into the 10s.
    Once I'm there, I'm going to stop beating on this bike, and pick up a dedicated race bike.
    I'm the left lane BTW :biggrin:
  2. ridervfr
    Pretty Kewl!!! What kinda bike where you running against?
  3. fastrax203
    fastrax203 New Member
    Chesapeake, VA
    From the numbers...a Ninja 500? A Harley? Hahaha
  4. Elseebee
    Elseebee New Member
    Actually it was another VFR!
    ......a VFR 500!
    The guy was super consistent though, and all night he was desperately trying to go 100mph.
    I guess you don't have to be fast to want to go faster!
  5. phobe
    phobe New Member
    Calgary
    A PC, juicebox, or bazzaz z-fi won't do anything for the 1st and 2nd gear bog. It is an ignition retard, and you need a TRE. Nobody offers one yet, but I hear Bazzaz is working on a Z-bomb.
    The good news is you can hack it yourself easily. That will get you into the 10s.
    check out my blog: vfr1200fa.blogspot.com
  6. knobby1
    knobby1 New Member
    Sydney, Australia.
    Unfortunately not for the DCT riders among us....the "hack" won't work for them :frown:
    I have seen a VFR1200FA get into the 10's at my local drag strip....was a 10.8xx @ ~129-130 mph if I remember correctly...ridden by a guy who looked like a midget jockey, he would've been lucky to weigh 55kgs!! I'm pretty sure I've done turds that heavy :wink: He carried the front wheel for a fair distance too, maybe 10-15m or so, sure surprised me.
    Cheers,
    Smithy.
  7. Elseebee
    Elseebee New Member
    What are you eating!!?
    LMAO!!!
    So, I guess I'm waiting on the Bazzaz module for the gear position hack. I don't want to cut my harness.
    As far as the DCT thing, I don't think the tech is quite up to par yet, and now that I hear you can't dyno them, it makes me even happier that I got the regular old clutch and shifter model.
    I spoke with my local dealer and told them about the power hole in 1st and 2nd gear. They ran it up the chain, but I haven't heard anything back. I hope Honda releases a proper map that eliminates the problem rather than force us to concoct workarounds. Maybe someone can engineer an ECU flash (HOPING)
