Tools for longer rides?
Discussion in 'Gear & Accessories' started by Firehand, May 18, 2013.
  1. Firehand
    Firehand New Member
    For rides over, say, 500 miles both ways, are there any tools and/or supplies you like to take along? Chain lube, wrenches, whatever?
  2. ridervfr
    flat repair kit with co2 cartridges, assortment of wrenches 8-10-12-14...1/4 ratchet with same assortment of sockets...can of chain lube. You chain should not require adjustment, but if it does, you have your tool kit that came with the bike. Sure some other pipple will add some stuff I forgot.
    You may wana take some bandaids, bug spray and sun-tan lotion...pint of gin maybe too??? :drinkers:
    Cheers...
  3. Scubalong
    500 miles both way........That would be half day ride for us here in So Cal
    I just loop my chain the night before, check to make sure I have fix a flat kit in my tank bag, a towel and a small bottle of face shield cleaner. Get my visa card, passport, some water.......Hit the door here I go:vtr2:
  4. duccmann
    an extra collarbone---sorry Long, I had too-----:crazy:
  5. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    Some medicinal herbs. :tongue:
    Rollin
  6. ridervfr
    does that include the "medical mariuhauna card." :nelson:
  7. Scubalong
    Bastard
    Duccman>:chairshot:<Long
  8. Firehand
    Firehand New Member
    I've got a small first-aid kit I keep in the trunk(band-aids, antibiotic, burn gel, few other things) all the time. And the flat kit. So those two I'm good on.
    Though a small bottle of Scottish Holy Water I hadn't considered.
  9. Scubalong
    Sound like you are ready for the trip than........Have fun and be safe.
  10. 34468 Randy
    No such thing. They are all big bottles. Highland Park 35 has the greatest healing properties.
  11. squirrelman
    A new headlight bulb, some wire and electrical or duct tape, fuses, along with the toolkit.
    Spare R/R too if you have one.
  12. Marrib
    Marrib Insider
    Phx, AZ
    Highland Park: Tastes like bad gasoline stored in charcoal from a burned cat.
  13. 34468 Randy
    I have a very small L.E.D. flashlight zip tied to one of the cables on the throttle side of the handlebars. Very small. Like about the length of the first finger section of you pinky finger. They are waterproof enough to handle whatever rain gets in there and is always available to you if and when you need it.
    A closer view. What you cannot see here is that there is a clip that makes retrieval of this light from the cable very easy.
    In total darkness, you should be able to feel your way to this light. Before you pull it off the cable though, turn it on. If you drop it, you will be able to find it easier in the dark. You need not ask why I am familiar with that aspect of this.
  14. Arnzinator
    Arnzinator New Member
    Central Massachusetts
    +1 to a small flashlight w/ fresh batteries.
    A foldable map preferably laminated if your unfamiliar with the area your traveling in. Good back-up if your using GPS/ smartphone & have poor or no reception.
    Don't forget cellphone charger.
    If your going to be camping at least 2 ways to make a fire (lighter, waterproof matches, flint/ striker).
    A good quality multi-tool (Leatherman, Gerber).
