torque setting for sump plug
Discussion in '5th Generation 1998-2001' started by Seriesman, Feb 27, 2021.
  1. Seriesman
    Seriesman New Member
    Scotland
    Hi Folks havent got a manual yet. can someone tell me to torque setting for the sump plug please?
  2. raYzerman
    raYzerman Member
    Millgrove, ON
    The manual says 29 N-m or 22 Ft. lbs. No need to exceed that.
  3. Seriesman
    Scotland
    Maybe someone should have told previous owner! no washer and plug that tight im surprised it didnt bring a bit off the crankcase with it!
  4. Seriesman
    Scotland
    And Thanks.
  5. raYzerman
    raYzerman Member
    Millgrove, ON
    My experience, using the Honda aluminum washer, anything over that will eventually squeeze out the aluminum until it starts wrapping around the head of the drain plug. I usually don't use a torque wrench, have trained myself that a certain amount of snug is good (you can feel the washer starting to squeeze)... check with torque wrench revealed that was 20-22 ft. lbs.
  6. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    I don't use a torque wrench either, just a little bit past snug. Tight, but not OHMYGAWD tight.
    VFRIRL likes this.
  7. Seriesman
    Scotland
    Wish whoever fitted the oil filter followed this!
    cant get it off its on too tight. filter wrench is crushing the filter rather than turning it !!
  8. raYzerman
    raYzerman Member
    Millgrove, ON
    Same with a torque wrench on the filter... follow the filter manufacturer's instructions.... a bit of oil on the gasket, install until gasket contacts base, tighten another 1/2 turn. Much easier to get off next time.
  9. Seriesman
    Scotland
    Yep guess im going to have to hammer a screwdriver through the canister and try and get it to turn.
  10. Thumbs
    Thumbs Member
    Bath(ish)
    Yup ....had to do that on mine .... while putting the screwdriver away I found the tool that fits on the end of the filter, the one that comes free with the Honda filter
  11. Seriesman
    Scotland
    Got a tool coming but im getting impatient now lol
  12. raYzerman
    raYzerman Member
    Millgrove, ON
    This type works pretty well..... doesn't have to be a branded one.
  13. Seriesman
    Scotland
    Got one like this coming but have gotten impatient. Screwdriver eventually did the job. Thats the bike serviced, just chain to adjust, put tghe bodywork back on and then give it a clean.
  14. VF1000Fe
    VF1000Fe New Member
    Alberta
    2006 VFr800;
    Get a Torque Wrench and Always use it.
    Seriesman and VFRIRL like this.
  15. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    For all the extras and 'improvements' we make to bikes, the most important things are to change the engine oil and filter regularly, keep tyres at the correct pressure and with good tread, and keep the chain cleaned lubed and tensioned properly.
    NorcalBoy likes this.
  16. Seriesman
    Scotland
    Thats excellent . Thanks
  17. squirrelman
    'ow many times 'ave i done that, laddie ?? :eek: still don't 'ave no proppa tooks.
  18. mello dude
    Generally Honda factory manuals are excellent, but sometimes......
    Sorry 19 ft-lbs on an oil filter and 22 ft-lbs on the drain plug is too frickn much!
  19. raYzerman
    raYzerman Member
    Millgrove, ON
    I suppose we should mention that torques are usually specified "dry", and must be reduced significantly when "lubricated". I'll never understand why there's a torque spec on an oil filter.... none of the filter manufacturers specify that method of installation.
    mello dude likes this.
