Torque spec for rear sprocket nuts?
Discussion in '1st & 2nd Generation 1983-1989' started by 5891Jonathan, Nov 24, 2006.
  1. 5891Jonathan
    5891Jonathan New Member
    Juneau, Alaska
    Anyone know what the torque spec is for the rear sprocket nuts on my '84 VF750F? I am thinking about 50 ft lbs, but what do I know?
  2. RVFR
    Tight is tight, this is one area that I know to tight is just as bad as not tight enough..on the 954 it's 84lbs. if nothing else find a spec sheet that has torgue values for the size of bolt, that should be close enough.
  3. daffy67
    daffy67 New Member
    On a VTEC it's 58ft/lbs.
  4. RVFR
    you talking axle nut? cuz on a 84 there's a normal swing arm. 50lbs sounds good. For those of us that have the sssa, all we have are lug nuts or the nut that holds on the spindle, or for those that had the time and money or a RC30-45 the prefered single wheel nut. which I heard goes 90lbs?
