Torque wrench
Discussion in 'Mechanics Garage' started by HarryVFRooie, Oct 2, 2019.
  1. HarryVFRooie
    HarryVFRooie New Member
    Netherlands
    My torque wrench is old. Like 20 years.
    I relax the spring every time after use.
    Should I wory about the right torque?
    How can I check?
  2. hondaman219
    hondaman219 New Member
    maine usa
    torque wrenches should be calibrated annually. So you have done it like 20 times now right. In reality it is cheaper to buy a new one then have an old one calibrated. Without special equipment you can not check it yourself. Check out harbor freight. They have a nice digital line for little money. Cheaper with a 20% off coupon. Do not buy a cheap cheap torque wrench. I have like 8 and have never had any calibrated. For what its worth
  3. 34468 Randy
    I have never calibrated mine but did read up on it. Seems to me it is a fairly easy process. Why haven't I done mine. Same reason I have not finished the cabinets in my shop.
  4. HarryVFRooie
    Netherlands
    I never calibrate mine either.
    Maybe I should Just buy a new one.
  5. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    You could just stick to a bending beam wrench, nothing to go out of whack unless you over-torque it. But the click-type
    are sooooo convenient.
  6. Vasco Gama
    Vasco Gama New Member
    Portugal
    You can actually calibrate it, check this video:
    RllwJoe likes this.
  7. scottbott
    scottbott Member
    Grantham,Lincolnshire,UK
    that was quite interesting, mine is a Norbar and probably 30 years old hardly used and stored with it slackened off so I may have a go at that sometime just to see if it is out spec
  8. Vasco Gama
    Portugal
    I tried this method and it works just fine. My torque wrench was very cheap(14€) and turns out it was only a few grams out of calibration, didn't even had to adjust the spring.
    scottbott likes this.
