TRAC system knob
Discussion in '1st & 2nd Generation 1983-1989' started by pghmailman, Aug 20, 2008.
  1. pghmailman
    pghmailman New Member
    On my '86 VFR700F2 the TRAC system knob on the forks no longer shows the numbers 1-4 . There is a raised arrow like spot on the knob and an arrow on the fork tube. Would the one on the knob correspond to the # 1 setting ? If so do I turn clockwise or counterclockwise to get to # 2 setting ?
  2. Tedric
    Tedric New Member
    Derbyshire. UK
    Hello mate, just checked on mine for you.
    The numbers from 1 - 4 go anti clockwise, therefore if you are at position No. 1 you will turn the knob clockwise to get to setting No. 2.
    Hope this helps & also there is a small dimple on the face of the knob (where the sticker was/is), this I think is relative to position 1 but not 100 % sure, you may have to do some trial n error.
    Remember position No.1 has the least anti dive effect while position No. 4
    has the greatest.
  3. Yonan
    Yonan New Member
    TURLOCK, CA
    Trac Pic
    Here you go.......
  4. pghmailman
    Thanks all :smile:
  5. Chris71Mach1
    Chris71Mach1 Member
    Grand Prairie, Texas, United States
    so im curious, how does this adjustment help handling (like how does it feel different, what would one look for to judge where to set this)?
  6. squirrelman
    it controls front end dive under braking
  7. Chris71Mach1
    Chris71Mach1 Member
    ok so does that mean that set on 1, the front end would be all soft and mushy under braking and dive really hard with 4 being the least forgiving setting, or would it be vise-versa?
    also, the knob on mine doesnt seem to have stops on it, so it will just spin around and around (though it will sit in either of the 4 positions...theres just no lock-to-lock type of turning to it) is this normal, or is something broke on this?
  8. squirrelman
    statistically, about 85% of the '86 VFRs ( and '87 ) i've seen have the dial set on #3
  9. Yonan
    Yonan New Member
    TURLOCK, CA
    Mine spins all the way around too. I don't think its broke, just how it is.
    1 is soft 4 is hard. I'm a big boy I have mine set at 4. Only comes in to play when your on the brakes. Still needs stiffer springs.(winter project)
  10. pghmailman
    Mine has definite clicks to be felt.
  11. squirrelman
    Progressive ( brand) springs do wonders for the front end., but their recommendations for spacer length may be incorrect......
  12. Gatekeeper
    Gatekeeper New Member
    You're in beefalo and your bike is in AZ? You can't ride much that way!
  13. squirrelman
    i have an '86 RWB with 35, 000 miles here in barf-a-load (same one i've owned since 1990) that i'm using for daily commuting until i get time to install my new chain on the Hawk.......
