Trip-meter knob screw removal?
Discussion in '1st & 2nd Generation 1983-1989' started by schrocketeer, May 24, 2020.
  1. schrocketeer
    schrocketeer New Member
    North Alabama
    Are there any tricks about getting the very small Phillips head screw out, that secures the knob for the trip meter? I've left it to soak with penetrating fluid (PB-Blaster) for several days. Also I've tried a heat gun. The screw is still in there tightly.
    I recently restored a set of gauges and I removed this screw without much of a problem. I could see an issue with dissimilar metals corroding themselves together, as the screw is steel and the shaft it screws into is brass. The screw I removed, had green thread locker on it, but it came right out. Just make sure you use the right size screwdriver to get a good purchase.
    schrocketeer likes this.
  3. cknight
    cknight New Member
    Daytona Beach, FL
    For fighting corrosion, ACF50 is your best bet to release that interference. Regards, Chase
