Troubleshoot bad speedo
Discussion in '3rd & 4th Generation 1990-1997' started by 92yellowveefer, Mar 24, 2009.
  1. 92yellowveefer
    92yellowveefer New Member
    Hingham, MA (south of Boston)
    So a while back - okay, four years ago - my speedo/odo quit. So far I've used the tach without issue. Over the winter I finally got around to looking at fixing it. I bought a new speedo cable, thinking that would be a quick fix, but no good - still doesn't work.
    Before I start tearing anything apart, I wanted to see if anyone out there had any experiences and/or tips for quickly troubleshooting and resolving.
    Any and all advice will be greatly appreciated.
    Thanks All
  2. reg71
    is the needle broken? I know it's not very likely, but I suppose it could happen. If it sat for so long and got kind of stuck, then when you hooked up the cable it might have just snapped there. Also, where you connected to the bike, try spinning the cable manually somehow and see if the needle moves...
  3. 92yellowveefer
    It's never sat very long - other than over the winter of course. But the trouble started in the middle of the summer. And the odometer stopped working at the same time, which led me to believe it was the cable. With the cable ruled out (and I do need to manually turn it to confirm that - good point), it only leaves the box assembly/speedo joint down below...
  4. Rev
    Rev New Member
    Olympia,WA
    Ya, if you replaced the cable then I'd look at the connection to the wheel; maybe the 'gear' (or whatever it is) is stripped out.
  5. Longerfellow
    Longerfellow New Member
    Pollock Pines, CA
    Often enough the little tangs (for lack of a better term) in the speedo drive get folded over during a hasty installation while putting on the front wheel.
    Thanks again Rev!
  6. Mario98
    Mario98 New Member
    Santa Fe, NM
    i have a gen 5 but same thing happened except min would register a slower speed then no speed after a while. mine was an easy fix, speedo sensor that runs from the connector to the front sprocket. swaped em out and good to go
  7. Longerfellow
    Pollock Pines, CA
    Oops, wrong bike, sorry.
    Thanks again Rev-
  8. gh53821
    gh53821 New Member
    Upper Hutt
    I had a cable go on my 90FL. If it's a cable drive, then it's driven from the front sprocket bolt via a plastic "nut" (1st weak link). The plastic nut is part of the drive assembly bolted to the sprocket cover. Remove the cable at this end, spin the back wheel and the drive should turn.
    If a new cable is to be fitted check the speedo end turns when connected to the drive end.
    Routing the cable is fiddley and access to the back of the speedo head is restricted without taking everything to bits.
    If you don't get the fit onto the speedo head correctly, it won't drive the speedo.
    Anything after that and I'm afraid you are on your own.
  9. jay956
    jay956 New Member
    Richmond, Virginia, United States
    i had to replace that plastic nut a few weeks ago, it was just worn out. simple fix, just takes a screw driver.
  10. 92yellowveefer
    GODDAM that is some "fender" in your avatar pic. Is that thing made of steel?
  11. mikeyv
    mikeyv New Member
    Toronto, ON
    Yep, nice avatar.
    As for the speedo, if it was falling back and not recording actual speed and then finally stops functioning, the part you need is what I replaced last year. I replaced the nylon nut drive which is attached to the bottom of the speedo cable, just a screw driver away. Part number 44808-MR7-013. Very simple fix.
    Good luck.
  12. Sagi3
    Sagi3 New Member
    In my house
    That is exactly what mine is doing :frown:
    Could someone please tell me how to find the speedo cable :thumbsup:
