Two ?????'s
Discussion in '1st & 2nd Generation 1983-1989' started by Yonan, Jan 31, 2009.
  1. Yonan
    Yonan New Member
    TURLOCK, CA
    First ?
    Got a question about the front wheel bearing spacer inside the wheel. Mine has three tabs on one end of the spacer and since it flew out with the bearing I'm not sure which side the tabs should be on or what exactly they are there for. Will post a pic later
    Second?
    When replacing the head bearings with tapered ones do I still use the same torque specs the manual list for stock style bearings?
    Thanks guys
    the washer with tabs is for speedo drive and faces out
    tapered rollers require different torque specs and proceedure.
  3. Yonan
    Yonan New Member
    TURLOCK, CA
    I'm good with the washer this spacer is what I not sure wich side the tabs face or if it matters?
