Tyre Shine
Discussion in 'General VFR Discussions' started by VifferDude, Mar 20, 2009.
  1. VifferDude
    VifferDude New Member
    Sydney Australia
    The morons at the carwash put that Silicon tyre shine on my bike after I explicatly told them not to. I've made it home, question is,....what's the best way of getting this stuff off?. Does it soak into the rubber?. Hope I haven't got to buy new tyres?
  2. hondajt
    hondajt New Member
    springboro, oh 45066
    its most likely an appearance only compound, and will wear off after a couple more washes.
  3. cuttingedge
    cuttingedge New Member
    Bergen/ Rockland
    Most Commercial Tire Shine Products are Silicone Based.
    A sponge with some warm soapy water should get most of it off.
    I personally would wipe them down acouple of times and then hose it off.
    You can also use a Mild Degreaser such as diluted Simple Green or other product to help remove the silicone. I dilute most Degreasers 20:1 Water to Product for these types of applications.
    Jason
  4. rc24rc51
    rc24rc51 New Member
    Liberty SC
    Man, i'd use some brake cleaner if there was any on the tread surface!
  5. 1luckydude
    1luckydude New Member
    Shreveport, LA
    just soap and water and a scrubby sponge. No harm done. You won't spontaneously blow up or inexplicably fall down while riding down the street.
    Once washed off, go to your favorite twisties and scrub them in again. Done.
    Did they only apply it to the sidewalls?
  6. waldrm
    waldrm New Member
    SE North Carolina
    shine
    A good surfactant like sodium hydroxide solution will remove it. Spray it on, scrub or pressure wash and you are done. And watch those car wash wankers carefully!
