Tyre sizes
Discussion in 'Mechanics Garage' started by Waylander, Aug 17, 2020.
  1. Waylander
    Waylander New Member
    Waltham Abbey, Essex, UK
    Hi Guys, Girls.
    I am wondering if its possible to go up a bit in tyre size, the Manuel, says 140 / 80 17 69v, now choices are a little thin,
    would it be possible to go up to say 150 or 160 / 70 0r 60, without fouling the swing arm or anything else in the rear
    I really need to replace it, the DOT date is 06 2007, dont like the idea of a 13 year old tyre........................
  2. raYzerman
    raYzerman Member
    Millgrove, ON
    Measure what clearance you have..... tire size widths are in mm, so 150 is 5mm wider on each side. I've never had a problem going up one size in width.
    Profiles of 70 or 60 are aspect ratio, so will be a smaller diameter than an 80 of the same width.
  3. squirrelman
    no more than one size up.
  4. Waylander
    VF1000F2F, in bits
