Ugh! Clutch Fluid Leaking
Discussion in '1st & 2nd Generation 1983-1989' started by slowbird, Apr 14, 2010.
  1. slowbird
    slowbird Member
    Toronto, Ontario.
    So I'm leaking fluid from the clutch cylinder near the front sprocket. Got all over the sprocket and chain and I can hear it "hissing" when I press the lever.
    What is the general fix for this? You replace the entire cylinder or rebuild it?
    (Not the Cylinder near the clutch lever but the lower one)
    Rebuild kit contains main seal, low cost and easy to do.
  3. slowbird
    slowbird Member
    Toronto, Ontario.
    Sweet....thanks Squirrel. :)
    Kit available from Honda?
  4. The_Hamster
    The_Hamster New Member
    I see them on e-bay regularly.
  5. slowbird
    slowbird Member
    Toronto, Ontario.
  6. Fazer1Sniper
    Fazer1Sniper New Member
    Yes, Sir. It's the slave rebuild you need. As far as a gasket, the last one I did was on my '82 Magna V45. There was no gasket availible so I got a sheet of gasket material and cut one out. Worked fine with no worries. Good luck to you.
  7. slowbird
    slowbird Member
    Toronto, Ontario.
    Thanks everyone.
    Any recommendations for replacement fluid? DOT 4?
    Any bleeding tips.....will be my first time.
  8. Alaskan
    Alaskan Member
    Alaska
    DOT 4. I broke down and bought a Mityvac bleeder, but Elwray here on the site uses a clear plastic bottle with a hole cut in the top. Stuff the tube in the hole and you're good!
    BTW, a squirrel AND a hamster posted here! What gives with all the rodents?
  9. invisible cities
    invisible cities New Member
    new york
    +1
    Purchasing a Mityvac is well worth the extra nickle. Hydraulic fluid isn't much fun to work with and this tool makes the job much easier.
    MV8020 Brake Bleeding Kit
    Includes the original Selectline hand vacuum pump and all accessories necessary to perform one-person brake bleeding on automobiles, motorcycles, ATVs, snowmobiles, etc. Also works great for siphoning or transferring fluids from tanks and reservoirs.
  10. slowbird
    slowbird Member
    Toronto, Ontario.
    Sweet. Thanks everyone.
    I got the kit off Ebay and a cheap 1 man bleeder kit from Canadian Tire + 2 big bottles of DOT 4 Brake Fluid.
    I mights as well bleed the Brakes after I finish the clutch too.
  11. elwray
    elwray New Member
    Central NJ
    Did someone say my name???
    If you've got two people, you can bleed it without any special tools. You can probably do it yourself if you're flexible. The Mityvac is a nice investment though.
    We just used a water bottle, popped a hole in the cap, stuck one end of the tubing in the hole, the other on the bleed valve. Open the valve, and have one person pumping the lever and pouring new fluid in the cylinder, once it starts coming out clear the lever-man holds it closed/engaged while the valve-man closes the bleed valve.
  12. Mobtown
    Mobtown New Member
    Baltimore, MD
    If it was me...I would use this opportunity to rebuild the master (also easy) as well. Nothing like knowing that a system is new from front to back...
  13. slowbird
    slowbird Member
    Toronto, Ontario.
    I was always told in regard to a lot of systems on our bikes:
    "If it ain't broke...don't fix it."
  14. Mobtown
    Mobtown New Member
    Baltimore, MD
    Yeah, well the cost for the kit is nominal and since you have to open and bleed the system anyway...
  15. slowbird
    slowbird Member
    Toronto, Ontario.
    Very true.
    ...and I'll be honest and say that it had crossed my mind. Even thinking of installing steel braided lines too.
    But I would rather sink as little $$ into this bike as possible. It is nothing but problems for me.
  16. slowbird
    slowbird Member
    Toronto, Ontario.
    Slave repair kit arrived today.
    Looks like 2 rubber seals, the spring and the bleeder screw cover.
  17. Alaskan
    Alaskan Member
    Alaska
    Don't spend any extra money on this bike UNLESS you have money to spare. If it's a hobby and you have the $$$, have fun! But at the end of the process it will still be nothing but a 1986 VF500F with a VF500F engine, a VF500F valve train, VF500F carbs, etc.
  18. slowbird
    slowbird Member
    Toronto, Ontario.
    You are absolutely right. I have been feeling this way for awhile now.
  19. Alaskan
    Alaskan Member
    Alaska
    Yeah, I have a 1984 VF750F. My HEAD knows that I shouldn't put any extra money in it, but my HEART says it would be fun to upgrade the shock, mount F2 wheels with radial tires, yadda yadda yadda. Help! I am crazy!
    But, I cannot complain. The bike keeps me busy - replacing leaky fork seals and cracked clutch pushrod seals and worn-out cam chain tensioners and blown head gaskets, searching for parts on eBay for hours on end, developing new and inventive profanities, Skyping with my mechanic brother while I try to figure out why the %&$#) parts won't fit right. The 2004 VFR just runs and runs and runs. What fun is that!??!
  20. slowbird
    slowbird Member
    Toronto, Ontario.
    .... I hate you.
