V45 gearing question once more
Discussion in 'General VFR Discussions' started by chancychal, Jul 26, 2015.
  1. chancychal
    chancychal New Member
    Grass Valley, California
    The sprocket ratios for my restored V45 are 17/44. An 18 front and 42 rear are available. Thinking of changing one or the other but not both to get the freeway rpm's a bit lower than the 5200 rpm rate at 70 mph indicated. The engine feels like it has enough torque to handle a bit higher ratio. Anyone tried this with an older or slightly newer model?
  2. Allyance
    Allyance Member
    Germany
    East Bay, California
    JT Sprocket has a chart for all the combinations for the VF750F. I am very close to getting mine back on the road, but I remember it pulling like a truck from 1000 RPM to 10K RPM, with no surge. Lower RPM at 70 means less acceleration, I would try and get use to it first, but then front sprockets are fairly cheap.
