Valve adjustment
Discussion in '6th Generation 2002-2013' started by RobVG, Jan 17, 2025.
  1. RobVG
    RobVG Member
    White Rock BC
    Is the valve adjustment for performance purposes, or is it intended to prevent a damaged valvetrain?
  2. RllwJoe
    RllwJoe Insider
    In my thinking, both.
    RobVG and bmart like this.
  3. Terry Smith
    Nothing to do with performance, all about longevity.
    The valve heads recede slightly during use which makes the valve stem sit closer to the camshaft. This means the cam-bucket clearance reduces with wear and (if you play the game long enough) you end up with a valve that is always slightly open. The worst issue here is that the valve then overheats and gets degraded and the seal is lost. I guess it does become a performance issue at that point... Valve clearances are set with the engine cold because operating heat causes the valve to lengthen which means the real clarance when running is really very small.
    squirrelman likes this.
  4. RobVG
    RobVG Member
    White Rock BC
    Great answer, makes total sense.
    Thank you
    bmart likes this.
