Valve cover bolt seal confusion.
Discussion in 'Mechanics Garage' started by iopsd, Jan 23, 2023.
  1. iopsd
    iopsd New Member
    Chilliwack, B.C
    Looking to do a valve adjustment, or atleast inspection before I depart on a big trip somewhat soon and noticed that the bolt seals for the valve cover appear to have two different part numbers.
    >90543-ML4-610
    >90543-MV9-670
    Are these effectively the same part? I can't find any difference in the photos of the part.
    Seals circled in diagram incase I wasn't clear.
  2. ridervfr
    It is a reuseable part in my experience. Same for the gaskets number 5 - I do have a new set that I bought a while back that sit inside my armour in my bedroom.
    iopsd likes this.
    They are the same part. Qty 8.
    iopsd likes this.
  4. iopsd
    iopsd New Member
    Chilliwack, B.C
    I figured that much, I just want to play it safe rather than tear apart the bike more than is needed.
    Alright, thanks.
    Those grommets are actually pretty critical. The valve cover bolts are shouldered (they bottom out when installed) and those grommets are what apply the pressure on the cover and gasket. I would have customers buy just the gasket and not the grommets (cuz they were too expensive for what they were) and then still have a leak when they were done because the grommets were too flattened from age.
    Not every time, but enough to have an "I told you so" chambered.
    Terry Smith likes this.
  6. squirrelman
    the washers need to be fitted with the copper-colored side UP........if i remember correctly.
    Yeah, with the ones that are hard like that , def.
    The Hawk is just a rubber grommet with a top chrome cupping washer. I literally just tightened down my Hawk covers before typing this with all new rubber... it was surprising how far I had to keep squishing before the bolts bottomed out. Quite the difference from when I removed them.
